Hard top nut fixing?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Dune_Goon, Jun 4, 2002.
  1. Dune_Goon
    Dune_Goon Registered Member
    Mar 9, 2001
    55
    Santa Maria, CA USA
    Has anyone ever run across my problem here? I have a '72 Jimmy with a double wall top, on the passenger side right behind the door two of the bolts snapped in the top. I figure I will get these out with some AC Delco penatrant and a good easy out. But my BIG problem is the nut that is in the top at the sun visor. It is no longer held in place, it just spins so I am unable to put the bolt back in. What do I do? How do I go about fixing this? Thanx a lot for any replies guys.
  2. JungleBoy
    JungleBoy 1/2 ton status
    Jan 31, 2001
    243
    Houston TX
    <a target="_blank" href=http://coloradok5.com/forums/showthreaded.php?Cat=&amp;Board=firstgen&amp;Number=151429&amp;page=&amp;view=&amp;sb=&amp;o=>http://coloradok5.com/forums/showthreaded.php?Cat=&amp;Board=firstgen&amp;Number=151429&amp;page=&amp;view=&amp;sb=&amp;o=</a>
    Some ideas in this thread
  3. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    if you can get a scrwe driver under it pru on it really har as you are backing it out.
    nathan
