Hard Top removal
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Adub, Jul 27, 2003.
  1. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    Tried to take the pos off today and got all the torx bolts out and it wouldn't pop off. Both rear corners where still tight to the body. What's the deal. Its an 89 Jimmy SLE with full interior.
    AW
  2. Curtis2kul
    Curtis2kul Registered Member
    Oct 15, 2002
    62
    Winston-Salem, North Carolina, United States
    The back part of the top has a couple of hidden bolts. you have to remove part of the rear paneling to get to them and then there are some guide pins sticking up near the rear (I guess so it wont slide off the side as easy). Dont forget that it might be a little hard to get off because the weatherstriping might be a little stuck.
    What i did was took all the bolts out and layed on my back and popped the top off by pushing up with my legs! Hey, it works! GOOD LUCK /forums/images/graemlins/k5.gif /forums/images/graemlins/thumb.gif
  3. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    Are the bolts underneath the same T40 tamper torx or do I need to go get some other special tool
  4. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    I think they are 5/8 or 3/4 no special tool.
  5. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    Just went and pulled one side of the trim and the there is one bolt (looks like 5/8) and one Torx head. The T40 was too small.
  6. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    Anyone?
  7. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Take the 5/8's bolt out. I believe the other one holds a little alignment pin that stays on the rail. You can take it off if you want, but it is the big bolt that holds the top on. You should be good after that. By the way you don't have to put that bolt back in when you put the top back on just comes that way from the factory. Good luck and enjoy /forums/images/graemlins/thumb.gif
