Hard top
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Sammy, Jan 30, 2001.
  1. Sammy
    Sammy 1/2 ton status
    Dec 8, 2000
    250
    Does anybody know how thick the hardtop is? I want to screw something on it from the inside.
    And what about taking off the coating. A mate of me took off the coating of a CJ hardtop and that turned out to be all but a vlat surface. Seems that the coating is there to cover such things up.
    "K5 Grand GT in the Netherlands."
  2. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    It varies, but I would guess 1/4" maximum thickness. The "texture" can be sanded off and the top painted to look just like smooth metal. I think that's what you wanted to know.....
    Michael[​IMG]
    <A target="_blank" HREF=http://www.jmartin.net/parker/goose.htm>http://www.jmartin.net/parker/goose.htm</A>
  3. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Years ago I installed a rear deflector wing from GTS on the hard top. These are installed by a combination of screws and advesive. If I remember correctly, the top seemed to have a double layer, at least around the back section and had some metal reinforcements in it.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    At the very back, around the rear window, it's pretty thick. Also, where you can see the support ribs going from side-to-side on the inside of the top, those ribs are pretty beefy. The rest of the top is very thin. Mine had a couple of holes drilled in it for a roof rack when I got it. Looks to be 1/8 to perhaps 3/16's of an inch thick in the thin areas.
    The sides appear to be thicker, probably to support the weight and hold the windows in place. I've run 1/4 inch screws into the thick area just above the side windows to install curtains without puncturing through the outside.
