hard water spots
Discussion in 'The Garage' started by bigbadchev84, Jun 22, 2006.
  1. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    how do you remove hard water spots? the complex sprinkler system ha been hitting the wifes 05' black civic. any suggestions?
  2. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    vinegar & water, or lime away , may want to rinse after the lime away, and towel dry the area (to prevent spots) :wink:
  3. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    Use a light duty rubbing compound on a soft terry towel. I use it on customers cars and it works great, and it doesn't take a lot of effort.:D
  4. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    I have always used vinegar and it has worked. I would be leery of lime away doing something to the paint but I have never tried it.
  5. 86haubs
    86haubs 1/2 ton status
    Nov 14, 2005
    196
    Lemoore, CA
    Grab a Mothers Clay Bar from your local auto parts store, it will take out stuuf in the paint you didn't even know was there. It is time consuming, but more than worth it in the long run! I did it to my Camaro and it took me a whole weekend to claybar the entire car, but I never saw it shine so brightly!
  6. 89K5guy
    89K5guy 1/2 ton status
    Jul 11, 2005
    174
    Ohio
    Definitely use the clay bar.I used it o my 2002 Ram Air T/A and removed the rail dust out of the rear bumper not to mention that after doing the whole car
    a fly could slip and fall on the finish now:haha: .
  7. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    This works very well! I had them on the glass of my old car for years and years and this took them all off (I actually used straight vinegar though).
  8. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Yeah, that's why I mentioned rinsing it off. I'm not sure what sort of effect it would have either. I would think it would be OK if you didn't leave it on long. Lime away would work pretty fast, so having it on too long shouldn't be a problem. The vinegar should be plenty good though.
  9. 4by4bygod
    4by4bygod 1/2 ton status
    Nov 13, 2003
    3,859
    With My Tinfoil Hat
    Get the car in the shade, and make sure the paint is cool before you start.
    get a clay bar, and wash the car.. get a panel good and soapy, then use the bar.. don't forget the windows.
    if the spots are still there after you rinse it off, spray some windshield washer fluid on the spots, and rub lightly with a microfiber cloth until it disappears.
    Now would be a great time to wax it, if you haven't done so..
    washer fluid and a microfiber cloth also works for getting the embedded bugs off the nose.
    Don't waste your money on the 'clay bar lubricant', all you need is soapy water, it'll work like a champ. And don't use it in circles, go in a straight line back and forth. ( same with the wax, you don't want any swirlies in there )
    Tom
  10. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    lime away will also work fine. we use it on our boat all the time with no problems.
