"Hard-wired" and mounted my $25.00 OBA
Discussion in 'The Garage' started by dontoe, Jul 25, 2006.
  1. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Been so long, I forget who was the brother CK5er that purchased and shipped me the compressors. Thanks again, though!
    I finally decided to mount it instead of carrying it in my locker. Now, it's "plug 'n play!"
    Now........
    How I was using it........
  2. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    I need me one of them. Whats all the distribution blocks(i think) on your fender for?
  3. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Does it work well?
  4. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Headlight relays, air horn compressor, 12VDC power receptacle in the cab and the OBA compressor. Fog/driving/rock lights later. And I have a 300 Watt A/C inverter I want to replace with a much larger one and hard wire it.
  5. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    35X12.50X15, 20PSI t0 32PSI in three minutes. :wink1:
  6. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I like the little "fuel-line-rubber-anti-vibration" footsies you put on it. :thumb: Turned out good. I'm still not sure if I want to hard mount mine, or keep it swapable between the other 4bys or not. Time will tell I guess.
  7. sunnyc123abc
    sunnyc123abc 1/2 ton status
    Mar 12, 2005
    636
    SoCal
    Whats that sensor for where the pressure gauge goes? and does it get too hot for the compressor sitting in the engine bay?
  8. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Pressure switch.
    On at around 90psi, off at around 140psi. I ain't sure if I want to plumb it to my sliders/rear bumper. Y'all think it'll burn it up?
    I covered it with a ziplock baggie to keep it clean, it gets very hot under use, pumping up four tires. Don't think it'll be bothered by the under hood temps.
  9. CB77GMC
    CB77GMC 1/2 ton status GMOTM Winner
    May 6, 2005
    771
    Heath Springs, SC
    Cool Beans. :D Ya got it mounted. Could put connector just inside pass door that's where my backup one is and you know primary is in driver rear wheel well.
  10. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    I have 2 of those units. They are being plumbed to a 10 gal. tank to make airing up quick (39.5' aren't small :wink1: ), and allow short bursts of air tools. I know a lot of folks that use them on a regular basis. They seem to be holding up well.
  11. mrk5
    Apr 20, 2004
    12,331
    1,039
    Northern Colorado
    I think that was me. I'm pretty sure it was. I remember getting (2) for somebody from NC. I guess it has been a long time. :doah:
  12. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Kool, thanks again Scott! I tried to get one or two several ways, and you came through. :bow: :bow: :bow:
    It works great, especially for the price. I'm keeping the other one as backup!
  13. mrk5
    Apr 20, 2004
    12,331
    1,039
    Northern Colorado
    I use mine quite a bit. Especially when B_to_C isn't around with his York for me to bum air off of.
