Hardtop must go back on...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ArrowheadK5, Sep 1, 2001.
  1. ArrowheadK5
    ArrowheadK5 1/2 ton status
    Aug 3, 2001
    252
    Northern MN
    It's getting to be that time of year again up here in Duluth (NOT kidding, it's getting cold), so I need to put the top back on the ol' 87...
    Anything I need to know before bolting her back on? Maybe some vaseline on the seals? Also, the manual says something about putting the bolts back in in a particular order, anybody do this?
    Thanks, Tom
    Four wheel drive, four wheel expenses...
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I've never had a torque sequence - I just do the cab bolts, then the rails from front to back. I like to spray the seals with Silicone spray - it keeps them nice and pliable, and safe from sticking.
    1 tequila 2 tequila 3 tequila Floor
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  3. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Sorry cant help you on this. Its still 100 plus here. Not only that it doesnt get cold enough to really have to worry about that. Just turn the heater all the way up.
    86 Jimmy 4"lift 35"MTRs Other cars 69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  4. ArrowheadK5
    Aug 3, 2001
    252
    Northern MN
    Thanks alot Dueler, you make me feel better. I've been using the heat full-blast for a few weeks now at night. Really sucks since I don't have a heated garage all my work on the truck has to end soon, too. Plus SCHOOL starts. So thanks, seriously, man.
    PS: At least I can go bird hunting soon! LOL
  5. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    We can go bird hunting here soon too. I was just joking with you, I am from Michigan. I know the kind of weather your getting. Thats why I moved out here.
  6. ArrowheadK5
    Aug 3, 2001
    252
    Northern MN
    Ah, you do understand. I was J/K anyway. What do you hunt down there?
  7. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    We hunt dove and quail.
  8. ArrowheadK5
    Aug 3, 2001
    252
    Northern MN
    So you've prob shot some MI Ruffed Grouse in yourday too huh. Oops, sorry, this is a 4x4 board, not a hunting one! Oh well, good luck this season.
  9. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Good luck also. :)
  10. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    i do cab bolts first then rail....just makes sense to me...get it tightened into the cab first and then flush it up and tight with the bead rails....if you did it backwards it seems to me like it wouldnt quite seal the same...
    1985 GMC C-10 Shortbed
    1984 Chevy K-5 Blazer
    1982 Chevy C-10 Longbed
  11. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    I just find 2 friends, some beer, and it's on. I planning on doing this around November though.
  12. OneLeft
    OneLeft 1/2 ton status
    Aug 14, 2001
    111
    Colorado USA
  13. 77Blazer
    77Blazer 1/2 ton status
    Aug 13, 2001
    197
    Long beach CA
    too bad you guys dont live in so cal :) I will give away mine for a six pack and 2 lap dances at the local nudy bar :) so if you want it just let me know. Its located in long beach CA
    350, sm465, NP205, 14 Bolt w/Detroit locker(465 ratio), Dana 60 465, 38.5 swampers
  14. mine's been on and off like ( insert whore clothing item here)... no leaks.
    yeah like they said some silicone will help the seal, and do the cab bolts first... actually, i have three bolts in the cab, and four in the siderails... that's enough in my case to keep it on, although in a crash situation it may rip out.... but if it's subjected to that kind of punishment it's probably toast anyway!!
    it's hot here in texas, too.... i'm ready for fall, then i aim the money from the jetski to the 4x4....
    greg
  15. White Knight
    White Knight 1/2 ton status
    889
    Ft Worth,Texas
    I lost the centering pins in the back section of the rails, makes the top easy to slide on...I start all the bolts starting with the cab, then tighten the cab first, then the rails..of course I only do this when it gets cold...hmmm it never gets cold here oh well the soft top will just have to stay on!!!
    Later
    Veni Sancte Spiritus
    Da Pacem Cordium
    White Knight
  16. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I usually start the rail bolts first but don't tighten them. Then I do the cab bolts and tighten them. Then tighten the rail bolts. As far as leaking, I have never treated my seals. But, make sure they seat properly. If one gets folded or has dirt or stuff on it, it could be a source of future leaks.
    Brian
    Click to see <a target="_blank" href=http://tx85gmcguy.alloffroad.com> My 85 Jimmy </a>
    Who put a stop payment on my reality check?!?
  17. collegeK5er
    collegeK5er Registered Member
    Feb 29, 2000
    59
    huntsville, TX
    i've had mine truck for about 2-1/2 years, no cab bolts and no leaks. i'm now running 6 clamps on the bed rails and still no leaks but i don't know if i'd recommed it for every one. i take my top off and on all the time. would hate to see mine in an accident.
    Doin' it all on a college budget
  18. 1986Blazer
    1986Blazer 1/2 ton status
    Jun 13, 2001
    511
    Key West, FL - Southernmost Point
    Well......I do not know about whore's clothing or other items mentioned here but.....in Key West, Fl, the coldest it has EVER been is about 42 degrees and that was in about 1890....the warmest is about 98 degrees in 1948. Sure, 42 is cool but bearable....I'll just keep the hardtop on for the "chilly"winters down here!
    <a target="_blank" href=http://www.geocities.com/keywestk5/KeyWestK5.html>http://www.geocities.com/keywestk5/KeyWestK5.html</a>
    So I says to him, I said, "get your own monkey."
    1986 K5, 350 GM Crate, 700R4, NP208
