Hardtop removal.
Discussion in 'The Garage' started by jhellwig, May 7, 2005.
  1. jhellwig
    jhellwig 1/2 ton status
    May 7, 2005
    420
    Bonaparte, Ia
    I am trying to remove the hardtop on my 83 but ran into 2 bolts that only want to spin. I look at the underside of where they bolt and only see a rectangular piece that holds the nut.
    Is there a way to stop the nut from spinning without removing the cap to put vics grips on the nut? It appears that that might just be my only solution.
  2. trailblazer86
    trailblazer86 1/2 ton status
    May 16, 2004
    112
    North Shore of Lake Ontario
    If you have taken the interior out to see the nuts moving you could squeeze the box that is supposed to hold the nuts with some vise grips.
    Or you could drill though the holder into the nut then tap a the hole and hold it with a bolt.
    Myself, I used a welder. Nice thing about working from the underside is that the welder doesn't burn the paint on the bed rails.
    Now If you break the nuts off inside the roof of the truck you will have a ltill more work to contend with.
  3. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    did you remove the side panels to look at them?
  4. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    DIE GRINDER !!!![/SIZE]Cut the heads off those bolts, take the top off, and then drill them out. :D
  5. jhellwig
    May 7, 2005
    420
    Bonaparte, Ia
    I think I might go with one of trailblazers I ideas. I didn't figure that the nut inside would be that big.
    I did pull the inside panel partialy off. Just enough to take a peak at what I was dealing with. I haven't torn into it much yet.
    As far a cutting the bolt off, I'll save that as a last resort.
    I would also like to ask where I could get a softtop and do I need a roll bar for one of those?
  6. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    The vise grip works. i also have two like that...
    Rene
