Hardtop removal
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Trigger, May 13, 2003.
  1. Trigger
    Trigger Registered Member
    May 5, 2003
    48
    Independence, MO
    I was told you should never remove the hardtop because it will always leak after you remove it. Is that true? If I start taking it off would clamps be the easiest thing to use to make it a quick on and off removal?
  2. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    If I am right and someone correct me if i am wrong the hard top adds stability to the body of the truck and I would think it needs to be bolted down not like a camper. I would use the bolts they were there for a reason. As for leaking depends on the condition of the gaskets that seal it they may be dry rotted and need to be replaced mine were so i bought new ones before I took it off and then put the new ones on .....Jason
  3. tmaxxer9
    tmaxxer9 1/2 ton status
    Feb 12, 2003
    195
    Minnesota
    well as far as the leaking goes it shouldn't. i haven't had any problems with mine. but as far as what to use for holding it on, it would use the bolts. but that is up to you.
  4. georgiared84
    georgiared84 1/2 ton status
    Sep 5, 2002
    487
    Austell, Georgia
    Well assuming you mean the half cab type, I wouldn't suggest using anything but the bolts. Clamps wouldn't be much easier than the bolts, and it would be hard to get clamps to secure the top of the shell to the half cab. As for leakage, the only time I had problems with mine leaking was last year when I put the top back on with the seal around the half cab folded under wrong. If you have good seals it is meant to be taken off with no problem.
  5. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    there is also a set way you are to tighten the bolts, starting from the ones bolting to the cab roof and working your way to the ends. Bolting the ends tight first then the cab could result in the cab not sealing and leaking.
  6. 82K5_6.5L
    82K5_6.5L 1/2 ton status
    Dec 4, 2002
    439
    Tucson, Az
    well i would agree to that.. the other day off-roading with the top off,u can notice a big difference..the roof over the cab pops and makes weird noises without that extra stiffness.. but for leakin,just put it back on, if it leaks, check the seals.. or just dont put it back on till it rains!
  7. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Yeah, pop it off, that's what it's designed to do! I would use the bolts to hold it on, I think clamps would be a pain in the arse. It only needs about 4-6 bolts to hold the sumb!tch on anyway....
