Harmanic Balancer bolt
Discussion in 'The Garage' started by cegusman, Feb 11, 2005.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I just replaced my harmonic balancer on my 6.2. I know I need to torque the bolt to 200FT/LB but do I need to use any thread lock or anti sieze?
  2. diesel4me
    Jul 24, 2003
    17,584
    945
    Massachussetts
    I would...
    I dont know if its reccomended,but I would but some threadlocker on the bolt threads,being a diesel they like to vibrate everything loose--but dont use the killer "green" locktite if you ever want to get the bolt off again!--and I wouldnt put any on the crankshaft or the dampers I.D.--its ok to do it on a small block that has no bolt(or one that has a broken bolt in the crank!),but I dont think its nessasary--I could be wrong though!---and 200 ft lbs?? that sounds like a lot of torque for a bolt that size!--are you sure thats the right spec??:confused:
  3. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Got this from the tread:
    140-162 ft. lbs on 82-84 models, and 200 ft. lbs on 85 and newer models. I'm not sure why the different specs. I don't think there's any difference in the parts between these years, but I think that GM decided to make that bolt tighter in 85. So I believe that 200 ft. lbs is the recommended spec for all engines now.
    http://coloradok5.com/forums/showthread.php?t=111136
