Harmonic Balancer install help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Liberator, Jan 4, 2002.
  1. Liberator
    Liberator 1/2 ton status
    Jul 16, 2001
    276
    Communist California
    I'm trying to figure out how far this thing is gonna go on. When the balancer is fully installed, will it snug up against the crank sprocket?
    Thanks in advance for helping!
    Bo
    If it breaks, it wasn't good enough!
    http://coloradok5.com/gallery/liberator
  2. 1bigk10
    1bigk10 1/2 ton status
    Dec 20, 2001
    151
    Medford Oregon
    It will bottom out on the crank but im not sure what to torque the bolt at unless you have a 327 that was produced before 68 (I think thats right?) on thoese you just get a block of wood and a BF hammer and hit it on as far as it goes.
    1982 K10 Silverado. [​IMG] 327 SHPE powerplant SM465/205,15"custom lift 38.5"TSL/SWAMPERS 12boltrearD44 front,3.73 gears.
  3. BrianK5
    BrianK5 Registered Member
    Sep 20, 2001
    58
    Omaha, Nebraska
    Don't use a hammer! It will wreck the main bearings in the engine. If you are using the correct install tool, when it stops sliding on the crank is when you should stop. Don't force it. Make sure that the key on the crank is lined up with the notch in the balancer, too.
    The one on the 305 in my Monte Carlo went on all the way to the timing cover, but it was much thinner than the one I put on the 350. There is a gap between the cover and the balancer now, so I had a mechaninc look at it and he said it was correct. When I did mine, I thought it should have gone on further, so I kept cranking on the install tool. I ended up stripping the threads in my crank and the threads on the installer. That was a stupid expensive lesson I learned there.
    Brian
    1985 K5 Blazer
  4. Philly87
    Philly87 1/2 ton status
    Jul 14, 2000
    465
    6
    El Paso, TX
    Brian's right!!! DONT USE A HAMMER!!!! I did this to my 87 and my motor began to knock after I installed the new balancer. It only had about 15,000 miles on the new motor at the time and now it knocks to this day. The balancer was tough to put on so I used some anti-seiz on the crank and on the inside of the new balancer and a Blue Point installer to get mine on. If I'm not mistaken I think the proper torque for the bolt was only about 65 ft.lbs. I can double check that in my Chiltons if you need me to. Let me know.
  5. 1975k5
    1975k5 Registered Member
    Feb 28, 2001
    44
    Alabama
    When I installed mine, I kept on until the pulleys were aligned perfectly. Since they were properly aligned before I removed the old one and both balancers were the same size; I deduced that my logic must be correct. by the way, it has been two years and no problems.
    Tom
  6. 1bigk10
    Dec 20, 2001
    151
    Medford Oregon
    Ask GM on howw to but a balancer on a 65' 327 smalljournal. They'll tell ya how right I am.
  7. 1bigk10
    Dec 20, 2001
    151
    Medford Oregon
    Check your chilton on a small journal 327 and see how right I am. Cuz theres no bolt that goes intothe crank its not threaded the balancer is a press fit.
  8. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    I used a 40 oz. hammer to install mine with a wood block, and a brass hammer... I found out later this was a big no no, but no problems so far (knock on wood)... [​IMG]
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>link to k5's</a>
  9. Liberator
    Jul 16, 2001
    276
    I've been using a rubber mallet, but I did give a few good whacks with a block of wood and a hammer! Hope I didn't screw anything up! I took the balancer back to the parts store and they ordered me another one (3502) plus a different one (3504). Don't know what the difference is but hopefully I'll have it all worked out tomorrow. Thanks everybody, for all the info.
    Bo
  10. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Those very-early crank are not tapped for harmonic balancer bolt because they were indeed early models and they hadn't learned thier lessons.
    Gm saw the error of its ways and driled and tapped it from at least '70 on.
    In case anyone's interested, GM also didn't cast in an oil-pump boss on the 55 and 56 blocks. They also figured out that was a bad idea and all blocks after that have that provision.
    -- Mike
    <font color=blue> Married to a woman who understands the need for <font color=orange>Hugger Orange. [​IMG] <font color=blue>
