Harmonic Balancer, Question?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by xplosuv, Nov 25, 2001.
  1. xplosuv
    xplosuv 1/2 ton status
    Mar 9, 2001
    515
    Sacramento, CA
    Hi all,
    I have found my harmonic balancer is hitting the cross member. what could this be caused by, I have checked my motor mounts and thats not it. when at low idle, the balancer hits. goes away at higher rpms. any thoughts.?
    If you cant go over it...GO THROUGH IT !!! <a target="_blank" href=http://www.CaliforniaK5Krawlers.com>www.CaliforniaK5Krawlers.com</a>
    75 Jimmy 11" lift with 40's
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Bad motor mounts...it's the only way the balancer can hit the crossmember. The rubber has prolly turned to mush.
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  3. 1975k5
    1975k5 Registered Member
    Feb 28, 2001
    44
    Alabama
    Does the balancer wobble at low rpm,s? If so, replace the balancer before you ruin a seal like I did.
    Tom
  4. xplosuv
    Mar 9, 2001
    515
    Sacramento, CA
    I was wondering if it would damage the seal or bearings. I guess both rigs running at the same time is just not to be.
  5. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    How did you check the mounts?
  6. sosamantx
    sosamantx 1/2 ton status
    Aug 14, 2000
    393
    somewhere in Texas
    has the balancer been replaced?? maybe someone put on a larger one?? also, what about the sway bar, has it been replaced as well?? I was going to put a larger diameter sway bar on my Nova, but ran into the same situation.
    <font color=blue>Steve Sosa a.k.a. "sosaman"</font color=blue>
    <a target="_blank" href=http://sosaman.home.texas.net/carpics.html>http://sosaman.home.texas.net/carpics.html</a>
  7. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    check your crossmemeber for crax also , motor mounts need replaced , mine came apart and almost took out my timing cover on my new crate motor , my friends camaro did take out the timing cover horrible things ....
    dents ....
    O R D's axles
    NO BREAKAGE :)
  8. dyeager535
    26,982
    191
    hes right, its the pieces that the motor mounts bolt to. Cracked. 99.9% sure. Dads truck was exactly the same way, both of the steel pieces were cracked, motor dropped low enough to rub the damper on the crossmember. Mounts were good.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
