Harmonic Balancer rubbing on crossmember...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Impex, Oct 1, 2000.
  1. Impex
    Impex 1/2 ton status
    469
    Chandler, AZ
    i just replaced my tranny mounts (sm465) and now my harmonic balancer is rubbing on my engine crossmember! Do i need to replace my motor mounts or is the energy suspensions tranny mounts to big?
  2. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    Most likely you just need to freplace the motor mounts, it's fairly easy to do. I would suggest not driving the truck(or running the engine) untill you fix this problem.
  3. realsquash
    realsquash 1/2 ton status
    Jul 12, 2000
    778
    SE WI
    My oilpan used to rub on the crossmember, but ORD motor mounts solved that problem. Yes, i'd get new motor mounts. I used new stock rubber ones and they mushed after about 1000 miles again.
    Squash
    http://www.trailrunners4x4.org/users/realsquash
  4. sosamantx
    sosamantx 1/2 ton status
    Aug 14, 2000
    393
    somewhere in Texas
    <font color=blue>I would start with the motor mounts. If you are still having the problem, you could change the harmonic balancer to a smaller one (diameter), but you will have to change the timing tab as well. - Steve </font color=blue>
    <font color=blue>Steve Sosa a.k.a. "sosaman"</font color=blue>
    http://sosaman.home.texas.net/carpics.html
  5. Impex
    469
    Chandler, AZ
    How about if i drop my tranny down just enough to clear my front crossmember.
  6. Big B
    Big B 1/2 ton status
    222
    fort worth texas
    I pu the eng sup body/tranny on my truck then my ballancer started rubing i went and got a new set of motormounts and it fixed my promblem .
    bigb4x4.coloradok5.com
