Harmonic balancer....
Discussion in 'The Garage' started by BIG*RED, Apr 29, 2007.
  1. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    So I was going to install a gear drive yesterday. I went to remove the large center bolt that holds the harmonic balancer to the crank shaft, and it was loose..hmmm i thought. So i reached in with my hand and pulled it right out..:eek1:
    The threads are compealty gone on the first 1/4 inch or so, and its all stripped out..
    So how long will a harmonic balancer stay on with out that bolt? I'm hopeing that since the balancer is pressed on there pretty good, and the fact that you have to use a puller to take it off, means that it will stay put..:crazy:
    What do you guys think?
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    The early engines, 265,283,302,327 never used a bolt. I would like to have the bolt for the added protection so i would say if only the frist 1/4" of threads in the crank are bad use a new bolt and install it.
  3. 5trucks
    5trucks 1/2 ton status
    Aug 12, 2005
    169
    Yuma Az.
    I concure but isn't it technically called a harmonic dampner.
