harmonic balancer ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CBLAZER81, Sep 12, 2002.
  1. CBLAZER81
    CBLAZER81 1/2 ton status
    Mar 3, 2000
    281
    Milliken,COLORADO
    Will the harmonic balancer from a 1981 350,4 bolt main, work on a 1990 350, 2 bolt main? I'm getting ready to build my motor and will need to get a new one if they aren't interchangeable. Just trying to figure out all the parts I need to order so I can get them all at the same time.
    Thanks /forums/images/icons/confused.gif
  2. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    I do not belive so... when i had my new tbi 350 put in, the shop had to order a new harmonic balncer simply becuase my old one wouldnt work with it... it was a 87 305 fyi so it might be diff if both are 350's
  3. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    I know that at some point in the 70s or 80s they changed the balancer and they wont interchange, but I'm not sure about the later models.
  4. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    should work with no problem. Timing marks may be different though.
    A 305 balancer will not work on a 350....ever.
    John
  5. dyeager535
    26,979
    Check diameter for one thing. There are at least two different chev balancer diameters (8" is the big one, all I've ever seen on a truck FWIW) and the timing tab is different based on the size (and year too)
