Harmonic Balancers
Discussion in 'The Garage' started by Muddytazz, Dec 16, 2002.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    How often do the two halves ever spin on the rubber spacer in the middle of them? Took my burb in to have the timing and carb fine tuned, and my mechanic (really good guy, knows his stuff) says it looks like the two halves have spun. He could only get my timing set at 22* /forums/images/graemlins/shocked.gif instead of the 8 or 12 or what ever its supposed to be(but that is according to the timing marks, its actually set correctly though). He got is all running right, its just that the marks don't line up. So has anyone ever hear or had or seen these things spin?
  2. rugger03
    rugger03 1/2 ton status
    May 14, 2000
    829
    around
    yes its quit common in the diesels, i would change it out asap. it has been the speculative cause of snaped cranks in the 6.2/6.5's.
    cheers
  3. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Except i'm not running a diesel, i've got a 350. Or would that still apply?
  4. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Yep....it happens all the time. I would recommend an aftermarket harmonic dampner, like the Streetdampner I have on my 388. No problems at all. /forums/images/graemlins/thumb.gif
  5. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    The rubber between the halves deteriorates with age and being oil soaked from the leaky front main seals that occur once in a while. You can get a fluid filled damper and that will keep that from occuring. High RPM's will also cause them to have slippage as well.
    John
  6. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    That happened on my 454. Got a new one from GM.
  7. desertrat67
    desertrat67 Hawk Driver
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    how much do dampers cost? I have an almost stripped out bolt hole in mine and am currently using JB weld to keep it tight. I have a 454 as well. Need to replace my damn pulley too. It fell off one day. Out of ballance now(wobbly)
  8. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    I priced them around and the cheapest I could find one for a 350 was at napa for $60
  9. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
