harmonic damper
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 4x4blazer, Jul 10, 2000.
  1. 4x4blazer
    4x4blazer 1/2 ton status
    Jun 14, 2000
    278
    Louisiana
    I am in the last phase of building my 350. I need to put the harmonic damper on and was wandering if putting it in the oven for a few, to make it expand, for ease of installation, would screw it up. Any suggestions?
  2. imconfused
    imconfused Registered Member
    Jun 16, 2000
    44
    I've never had any major problems installing a damper as long as you use the right tool or atleast a long threaded bolt with a nut and washer on the end to thread it on.(obviously you need to use a quality bolt with the correct threads)Feel free to apply oil on the inside. I'd be a little concerned with putting it in the oven only because of the elastic band. Hope this helps....
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I wouldn't cook it!
    I have been able to get my dampner on with no wobble by useing bolt and washer to push it on! DONOT hit it you will/could damage the crank and or the dampner.
    Summit sells a remover/installer if your looking to add to your collection???
    Rock ON![​IMG] 72 K5 [​IMG] Led Zeppelin
    http://burt4x4.coloradok5.com
  4. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    Please don't "cook" your damper, you WILL distort it and then vibrate until it blows apart take our advice use the proper tools.
