Has any one converted to Vortec TBI?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TEXICAN, Aug 6, 2006.
  1. TEXICAN
    TEXICAN Registered Member
    May 27, 2005
    30
    TX
    Just had a few questions if you have.
  2. K5Chris
    K5Chris 1/2 ton status
    Mar 11, 2002
    805
    New Orleans, LA
    i didnt do it but i did quite a bit of reserch on it, and talked to several people who did, and i decided against it. what are your questions?
  3. TEXICAN
    May 27, 2005
    30
    TX
    Was wondering what size TBI, cam, if they bought a chip.
  4. K5Chris
    Mar 11, 2002
    805
    New Orleans, LA
    use the 454 throttle body with either the stock 350 injectors (55lb) or the 9C1 cop injectors (65lb). the 454 injectors are too big. i know the edelbrock (non vortec) manifold has bores big enough for the 454 throttle body, but im not sure about the GMPP tbi/vortec manifold..... maybe go with an edelbrock vortec 4bbl manifold with an adapter?
    you could use the 350 throttle body, but the 454 one flows alot better.
    call up Comp cams, tell them what's in the engine & injection, and what you wanna do with it, and they'll build you a cam for your needs. then, call up Brian at TBIchips.com and he can burn a chip for you if you dont wanna burn your own.
  5. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    Ive done it on my 383. Pm me if you have any questions.
