Has anybody cut rubber H1 runflats?
Discussion in 'The Garage' started by josh86k10, Jun 13, 2006.
Which runflat beadlock ring to use?
  1. Buy the the conveyor belt rings
    0 vote(s)
    0.0%
  2. Use the stock Rubber runflats
    0 vote(s)
    0.0%
  3. Cut down and use the stock rubber runflats
    20.0%
  4. Mandatory nekkid option
    80.0%
  1. josh86k10
    josh86k10 1/2 ton status
    Feb 13, 2005
    423
    Knoxville, TN
    My 12 bolt H1 rims are recentered and I'll be putting the 39.5 TSL's on them soon. As always, funds are tight, so I am weighing my options. A conveyor supplier in Nashville will set me up with 1/2" conveyor belt beadlock rings (cut to width, length, and laced together) for around $26 per wheel. I've seen some made from 3/8" belt on tennesseeoffroad.com and they appeared to work great ( http://bb.tennesseeoffroad.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=27;t=000640 ). But, that involves me measuring, coughing up some cash, and driving 3 hours to Nashville and 3 hours back. I've already got the rubber runflats that came in them sitting here, so they would be the cheapest option. Should I just run them intact or will I cut a sidewall? Would the rubber ones work cut down, like the magnesium ones? (3 of them are 2 piece, one is 1 piece) Opinions?
  2. skidpan
    skidpan 1/2 ton status
    Sep 21, 2005
    226
    SOCAL
    dude i had thoes in my 325/85 16s ... i cut them with a saw zaw...:hack: i cut the O to make a C and then just kinda wound it out of the tire. I dont know how the hell you guys get them out whole. I dont like watching my bead stretching that much.
  3. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    2 ratchet straps, grease and a tanker bar
    I can break down and reassemble a HMMWV rim and tire assembly in about an hour and a half. When you squeeze the run flat in half they pop in and out pretty easily.
    EDIT: in answer to josh's question, no you will not cut a sidewall running them as they are
