Has anybody had PCV valve issues?
Discussion in '1982-Present GM Diesel' started by Can Can, Mar 28, 2004.
  1. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I was just reading on another site somewhere that if you notice an oily mist coming from your oil fill tube it means that your PCV filter may be pooched. I checked my fill tube today and did notice a bit of mist coming from the tube after I shut the truck off.
    Can someone fill me in on this? I've never replaced the PCV valve on my 6.2 because I didn't know how to tell if it needed to be swapped out.... /forums/images/graemlins/dunno.gif
  2. tRustyK5
    Jul 23, 2000
    36,181
    1,388
    E-town baby!
    A PVC is for a gas engine. The 6.2 uses a CDR valve, which
    I assume should be changed periodically. I really don't know the indications for replacement though.
    Rene
  3. Can Can
    15,552
    136
    Hmmmmmm.......I have a breakdown of my emission equipment and it clearly states that the part in question is a PCV valve.
    Maybe the non-EGR intakes(like yours) don't come equipped with said part? /forums/images/graemlins/dunno.gif
  4. tRustyK5
    Jul 23, 2000
    36,181
    1,388
    E-town baby!
    Mine has the CDR at the top/front passenger side of the motor beside the oil fill tube. There are a couple of rubber lines going from there to the inlet of the manifold.
    Rene
  5. Can Can
    15,552
    136
    I just spent a few minutes trying to find the page I was talking about. You're right, Rene, it's definitely called a "CDR Valve". I stumbled onto this page when I was trying to figure out if I had a blown head gasket/cracked head:
    LINK
  6. Can Can
    15,552
    136
    I wonder how accurate the "6000 miles" interval is? I've put over 100K on my truck and have never even given the CDR /forums/images/graemlins/wink.gif valve a second thought....... /forums/images/graemlins/eek.gif
    Looks like I'll be ordering a new one tomorrow!!! /forums/images/graemlins/1zhelp.gif
  7. tRustyK5
    Jul 23, 2000
    36,181
    1,388
    E-town baby!
    That link was discussed at some length by members with much more tech knowledge than I have. I was left with the impression that 'Don' is a first rate asshat that really doesn't know very much about 6.2's. /forums/images/graemlins/deal.gif /forums/images/graemlins/dunno.gif Maybe one of those smarty pants will chime in and give us the tech rundown again?
    Rene
  8. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Rene
    I remember that debate and I don't think you will get better answers this time.
  9. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I was just going to post a question regarding the CDR. This last weekend while working on my truck I noticed some oil residue in the intake....looks like I better do something about it.
    Does anybody know what should be done to "service the CDR"....or should I just get a new one.
    Is there anyway to eliminate the CDR (like just use a regular crankcase vent/filter). Yeah, yeah, I know it's part of the emissions but this truck is for off-road use only. /forums/images/graemlins/whistling.gif
  10. tRustyK5
    Jul 23, 2000
    36,181
    1,388
    E-town baby!
    I'd just replace it...doesn't look like a spendy part at all.
    Rene
  11. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    You could just run a "draft tube" like on medium and heavy duty engines that just lets the crankcase gasses vent to the atmosphere. You will need to make sure you keep water and junk out of it if you go wheeling.
  12. Can Can
    15,552
    136
    WRONG!!! Just shy of $70 /forums/images/graemlins/doah.gif from GM, and there are no aftermarket manufacturers that build CDRs.
  13. tRustyK5
    Jul 23, 2000
    36,181
    1,388
    E-town baby!
    How often have you replaced it? Spend $70 now and you'll likely never replace it again... /forums/images/graemlins/smile.gif
    Rene
  14. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    Hmmm, did an online search for the part. Napa doesn't list this part but Autozone lists a "PCV valve" for about $35. I know A-zone isn't always reliable, but I cross-referenced the part number compared to the gas engine and it was different....the PCV for the gas engine was like a $3 part.
  15. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I replaced mine a while back, paid $30-$35 at Oreill'y Auto Parts.
  16. tRustyK5
    Jul 23, 2000
    36,181
    1,388
    E-town baby!
    That $70 would be in Cdn funds at a cdn GM dealer. Still a bit high, but within range for the stealership.
    Rene
  17. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    yep that's what I have on my perkins. /forums/images/graemlins/grin.gif
  18. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    I need to do something with mine, but Autozone is the only place that lists the part but it's currently out of stock (as-in their warehouse is out of stock).
    Can I just remove the CDR and replace it with a filter or something?
