Has anyone any experience w/ the 80 deg. "bad boy double cardan joint?
Discussion in 'The Garage' started by TNS10HYBRID, May 9, 2003.
  1. TNS10HYBRID
    TNS10HYBRID Registered Member
    May 4, 2003
    21
    Has anyone any experience w/ the 80 deg. \"bad boy double cardan joint?
    Could it be ? If it is reliable it could solve a lot of my prblms.
  2. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    Re: Has anyone any experience w/ the 80 deg. \"bad boy double cardan joint?
    **I think** the 80* part is an agricultural piece that is not "sealed" like the regular CV on our trucks. I don't think it's rated for continuous use.
  3. 96chevysfa
    96chevysfa 1/2 ton status
    Jan 1, 2003
    230
    so cal
    And The 80 Degree C/V here you could mount your t-case on the hood and still hook it up- remember this its not for speeds above 30 mph on a constant run- and its the size of a 1 gallon paint can -7" diameter (it hits hits most automatic trans pans -)
    i could not find if it was sealed or not. do you really need 80 degrees though?
  4. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    i just say hook two factory CVs together /forums/images/graemlins/grin.gif
  5. SCOTTS_4X
    SCOTTS_4X 1/2 ton status
    Mar 22, 2002
    129
    Modesto CA
    yeah hook them together, I mean, what's the worst that could happen? /forums/images/graemlins/rolleyes.gif we'll leave this one to you and your truck pull buddies bowtie /forums/images/graemlins/rolleyes.gif
    -Scott
  6. TNS10HYBRID
    May 4, 2003
    21
    Yeah, I checked Driveline Solutions site and it has some info. It says 30 m.p.h. max. My truck is going to be off road only, but I don't want to have to worry about driveshaft speed. Is the limit supposed to be because of heat buildup? /forums/images/graemlins/rolleyes.gif
  7. juanblzer
    juanblzer 1/2 ton status
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    ask me about this company...I will attest to the poor craftsmanship and shoddy customer service every time. They are also called Arizona Driveshafts. DO yourself a favor and buy a www.highangledrivelines.com you'll get a guarantee and you won't have a big POS that breaks other components.
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    what problem are you trying to solve?
    the axle end will still be at a terrible angle unless you run some wierd link susp
  9. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    -Scott
    for future reference reading my posts /forums/images/graemlins/grin.gif=i'm joking
