Has anyone done this for more travel in the rear?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84k5, Aug 26, 2003.
  1. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    This doesn't apply if you're running a shackle flip, but if you're smart you can probaby answer this anyhow. I have 4" tuff country springs and greasable bushings in the rear. Yes, I put the right bolts in the right holes. The bolt through the shackle and spring hits the bracket that connects to the frame, stopping downward travel.
    Basically I want to cut it short enough so it clears and wont limit down travel. Is it safe to cut the bolt shorter, or do I need to buy a shorter one. (Don't know where I'd get one since it's greasable.) Can I cut it flush with the nut, or do I need to leave a couple threads to be safe? TIA
  2. patrickcampbell
    patrickcampbell Registered Member
    Sep 11, 2002
    60
    well cut the f-ing bolt as long as u dont plan on taking your rear springs off.
    PS: if you buy new bolts they dont have to be greaseable.
    Oh yeah and what the hell are you talking about the bolts hit, I have never seen the bolts hit and mine dont either
    /forums/images/graemlins/rotfl.gif
  3. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    Good job, you seemed to entirely miss the question.
    1. I want to know if cutting the bolt is going to weaken it. I don't know how far the grease channel runs through it, so I don't want to cut it too short and have grease just run out the other side.
    2. Why would I buy greasable bushings, then replace them with non-greasable bolts. Sorta gets rid of the point.
    3. You're right, it doesn't hit. I made it up for fun. You've seen every gm truck and you know better than me.
  4. BRN78BLAZER
    BRN78BLAZER 1/2 ton status
    Feb 5, 2003
    133
    Stoney Creek Ontario, Canada
    I'm not sure I quite understand, but if its what I'm picturing, could you take the bolt out and just reverse it. If its the thread end hitting, and you switched so the head end was on that side, would the bolt then clear?
    Hope this helps
    --steve--
  5. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    The greese channel only goes about 1/2 way through, you should have been able to see it when you put them in.... /forums/images/graemlins/deal.gif /forums/images/graemlins/thumb.gif
  6. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    I know what you are talking about, mine did the same thing. Cutting the end off the bolt won't weaken it, and as others have said the grease channel goes only about 1/2 way.
    You can't turn the bolt around because the Zerk would hit the frame, same as the bolt being to long.
  7. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    I haven't found the book or reference that explains it, but there is some "science" to leaving a little bit of thread stickout beyond the nut. I would try to avoid cutting it exactly flush....if you can leave a couple of threads exposed, I think you would be as strong as it is currently......(but with beter shackle movement!)
    Hole for grease is only 1/2 way down the bolt, then dumps out as a hole in the side which I'm sure you saw during installation.
    ps. I have a shackle flip, and still answered your question. /forums/images/graemlins/grin.gif
  8. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Yeah, the science is called.....
    "leave some thread exposed so that if in case of vibrations the nut wont fall off."
    I personally (one of these days) intend to just drill a hole through all of those suspension bolts to install a cotter pin. That way, I can loosen everything up, and have no fear of a nut falling off.
  9. tRustyK5
    Jul 23, 2000
    36,166
    1,363
    E-town baby!
    I believe you should leave half the width of the bolt past the end of the nut. 1/2" bolt...1/4" past the end of the nut.
    Rene
  10. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    Yeah I saw where the grease comes out, but wasn't sure if the other channel stopped there or what. Half its width sounds good to me. Hopefully that will clear.
  11. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    if its a harded bolt cutting can weaken it... but If your gonna do it go slow and try to keep it cool if your using a sal of some type keep it wet with oil.
  12. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    I haven't found the book or reference that explains it, but there is some "science" to leaving a little bit of thread stickout beyond the nut. I would try to avoid cutting it exactly flush....if you can leave a couple of threads exposed....
    It is written in most technical manuals... mainly those where torque values are critical, or areas where if the component were to come apart it could lead to serious injury or loss of life... such as heavy machinery and aircraft maintenance.
    Having said that, in your application I would try to maintain at least 1 1/2 threads past the lock nut, as has been said a few times....
