Has anyone ever done this??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FunBlazer, Aug 21, 2002.
  1. FunBlazer
    FunBlazer Registered Member
    Jul 30, 2002
    29
    Lake George, NY
    Use their AC condencer for a tranny cooler, when they removed the AC??
  2. FunBlazer
    Jul 30, 2002
    29
    Lake George, NY
    Someone must have tried this, I need to know if it worked , cause I want to try it on my Blazer tomorrow, if someone has tried it and if it worked please let me know. Thanks
  3. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    Not me.....
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I helped my buddy set it up on his dodge. Worked like a champ. The tranny never, ever, overheated.
  5. FunBlazer
    Jul 30, 2002
    29
    Lake George, NY
    How come everyone dosn't do it then? It's a whole lot bigger than one of thoes coolers that you buy in the store.
  6. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    ur tranny needs to run at between 170*-190* to work most effiently. having a cooler that large keeps it too cool. get what im sayin??? hell, a regular tranny cooler keeps it right where ya need.
    NITRO
  7. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    cool
    I would have guessed it wouldnt handle the pressure, not that I know how much pressure flows through the cooler lines...
  8. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    If your worried about it being to cool you can run it back through the radiator so that the water can warm up the fluid.
  9. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Isnt the low side of the AC system something like 32 pounds? I would not guess that the tranny cooling lines are much more than that. But like you I do not know what the pressure is either.
  10. FunBlazer
    Jul 30, 2002
    29
    Lake George, NY
    Well I did it today, and I don't think I'm gonna keep it that way, cause I realy don't like to use rubber hose. I have a decent size cooler and the tranny lines screw into it so I'm gonna put that on instead. I heard that pressures can get as high as 290psi in reverse, I can't conferm that though.
  11. harry
    harry 1/2 ton status
    Feb 9, 2001
    106
    san diego, CA
    how about using it for a power steering cooler?
  12. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
  13. dyeager535
    26,979
    Cooling lines don't get anywhere near that PSI, but using rubber lines for ATF is a great recipe for an engine fire if you ask me.
    Already had a hose heat fatigue, and rupture, spraying a nice stream of ATF on the exhaust manifold. You really don't have much in the way of choices in the cooler line issue, even the GM factory C/K tranny cooler I bought used rubber line. I just don't think its a very good idea, like rubber fuel line. If it can be avoided, great, but unless you custom make some lines, (you can) you don't have much choice but rubber.
  14. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Usually about 150 psi on the high side. Nothing steady though because heat and engine speed will change the pressures.
  15. YtseJam
    YtseJam 1/2 ton status
    May 19, 2002
    147
    CT USA
    Also keep in mind the function of the cooler, it is not necessarily to keep the trans fluid cool, but to regulate it. It works like a charm in the radiator, but if you need an auxiliary cooler, I recommend getting a good one designed for Automatics and use steel lines.
  16. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Have you tried a $30 tranny cooler from Autozone? It comes with adapters and mounting hardware, just do that.
  17. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Thats what I did. Its a B&M stacked plate cooler. I run a 2400 Stall converter so mine likes to heat up some. The cooler does just fine except for long periods of crawling on rocks on a hot day. It went up to 230 once. Normally stays at 160.
  18. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    The tranny only puts out about 150-200 psi, when you have a lot of throttle. The pop-off valve on the high side of an A/C system is usually 350psi or more, so the condensor must withstand that pressure. This should be the setup of choice if you tow with a 700 without lockup and with a high stall converter /forums/images/icons/smile.gif . Of course, if you tow in any kind of heat, you'll want the A/C to work anyway.
  19. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    is it full line pressure?
    I dont care about autos enough to do my own homework on them LOL
  20. Blue85
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    That's a good point, I don't know if the cooling lines see full pressure. At any rate, the condensor is probably good to a higher pressure than the rubber hoses that come with most tranny cooler kits.
