Has anyone here added A/C to a CUCV???
Discussion in 'The Garage' started by grimjaw, Aug 11, 2006.
  1. grimjaw
    grimjaw 1/2 ton status
    Jun 19, 2004
    944
    Seymour, TN
    I have a M1028 that I am looking to do a few upgrades to. I have been told by my wife to see about adding A/C to it. Rather than try and re-invent the wheel I thought I would ask here. Somebody has to done this before.
    My first thought was, OK just remove one from a Civilian truck. I would like to add a 6.5L turbo setup in the future and have heard that the stock A/C box on the under hood firewall is in the way.
    A few posts have referred to using an S-10 A/C box instead. I am not sure if it’s a direct fit or need to but ‘adjusted’ to work.
    The other, more expensive options is to use an aftermarket setup. Vintage Air has some stuff that looks like it would work but they are pricey.
    Does anyone have any experience with this? Thanks.
  2. Metrodps
    Metrodps Strange but nice guy Premium Member GMOTM Winner Author
    Jan 4, 2006
    9,727
    109
    earth
    I have seen it done. I know the ambulance has it but the alt is a big one. Will go look for some pics post in a few.
  3. grimjaw
    Jun 19, 2004
    944
    Seymour, TN
    The M1010 has stock A/C, but the M1008, M1009, M1028.... do not.
  4. Metrodps
    Jan 4, 2006
    9,727
    109
    earth
    OK only could find these right now but keep an eye on ebay and do a search for M1010 CUCV and save it then get emails when anything is added.
  5. k204dr
    k204dr 1/2 ton status
    Aug 27, 2004
    463
    TN
    I"ve recently done the s10 ac box with the 6.5 turbo setup, its not a bolt in deal. I had to cut the two a/c boxes and fiberglass them together. I'd like to see where the actual ac unit is on that truck in the pic. I see the compressor, but no ac box. sounds like the best if you can find one of those to put in.
  6. dremu
    Feb 27, 2000
    15,969
    462
    East of San Francisco
    Seem to remember the M1010's having a box above the cab for AC ... or was that for an AC unit for the amublance box?
    -- A
  7. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    is it easy to run AC with a 6.2? ive got a 350 now but if i swap to a 6.2, will i have to lose the AC?
  8. uao85
    uao85 1/2 ton status
    Jan 2, 2004
    1,867
    Edge of insanity
    Yeah I would also like to know about the a/c on a cucv, I have already ripped the heater off of the firewall, but am still contemplating on which route to take to convert it like grimjaw earlier mentioned. Only I have an m1008.
    Regards,
    Remington
  9. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Might try a place that specializes in A/C installation. We had a place install A/C in a couple of 1008's when I was in the service. The A/C was installed because the trucks were used for K-9 patrols. The installs were clean and we never had any problems with them.
  10. diesel4me
    Jul 24, 2003
    17,583
    945
    Massachussetts
    External A/C!..
    I've seen a few pickups and vans here using an A/C unit from an old RV like a Winnebago mounted on the roof!..bet cooling capacity isn't an issue!..:D
    I've seen a few home A/C units poking out of the back windows of pickups,and out the rear window of a few vans too..they must be using an inverter to get 110V to run them...either of those options would be easier than adding a factory A/C unit--and removeable when not needed!. .....:crazy:
  11. k204dr
    Aug 27, 2004
    463
    TN
    the only way the 6.2 is in the way of ac is if you use the 6.5 turbo setup on it. if you use a banks turbo or none at all it works just fine.
  12. grimjaw
    Jun 19, 2004
    944
    Seymour, TN
    The trouble is Banks wants $2000 for their turbo. The 6.5 turbo may be cheap even with the added A/C cost. I am trying to explore the options.
  13. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Ever thought of running "Vintage Air"? Might be a cheaper alternative to using factory components? I think there kit is 6 or 700 bucks. Most of which mounts inder the dash and is a standalone system minus the compressor under the hood.
    Just something to think about..
  14. grimjaw
    Jun 19, 2004
    944
    Seymour, TN
    Before I posted this I Searched here, SteelSoldiers, and the Dieselpage. There are a few Aftermarket companies that may work.
    This is a very good post from http://www.steelsoldiers.com/index.php?name=PNphpBB2&file=viewtopic&t=1083
  15. 85-m1028
    85-m1028 1/2 ton status
    Apr 26, 2005
    485
    costa mesa california
  16. grimjaw
    Jun 19, 2004
    944
    Seymour, TN
    Yeah, thats the Post that had the link to the one I reposted above. The problem is those guys are trying for the whole Authentic Military Vehicle thing. CK5 has a lot more experience with Chevys that anyone outside of GM. I am hoping members here have direct experience with this swap.
  17. k204dr
    Aug 27, 2004
    463
    TN
    you can buy just the turbo manifold from banks for $200. then just slap your own turbo own and plumb it. gotta custom plumb the 6.5 setup anyhow.
