has anyone here swapped there 10 bolt for a 14 bolt semifloater 6 lug?
Discussion in '1992-Present Chevy & GMC models' started by COCHEV, Dec 15, 2002.
  1. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    i've read lots of talk of it but want to hear from people who have done it. main questions are: what are the common r&ps in the semi floater 6 lugs? did they ever come with 3.42s? this is what i'm currently running and don't want to get into the front diff. any brake line, e brake line or driveline issues to know about?
    not interested in going solid front axle at this point. this is a daily driver and want to beaf the rear for mild towing and hauling tools.
    93 burb 1500
  2. Highjaxx
    Highjaxx 1/2 ton status
    Apr 17, 2002
    273
    Austin,Texas
    I put a 14 Bolt SF in my 86 Sub and the gears were 3.42, most are that come in the six lug, some are 3.73 though. It should be a direct bolt-up in your case, check the spring widths, if not cut off the spring perches and put new ones on. The lug bolts are slightly larger because its a 3/4 ton axle. It bolted up fine with my stock driveshaft and a 4" lift, I don't think the yoke is any closer. I had to swap the brakelines and e-brake on mine, I doubt you will. If so I just took them off my 10 bolt. Better brakes, and I got a full width axle unlike the 14 Bolt FF. I also had the shock mounts cut off and rotated up to increase ground clearance, and it gave the shocks less angle. Steel braided brake lines are also a worthy investment.
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Not first-hand info, but my boss used to do it on ex-cop K1500 Burb's he fixed up and re-sold. The cops would sell 'em off after the 10-bolt blew up. /forums/images/graemlins/wink.gif
    3.42 and 3.73 are the most common ratio. Make sure you get the rear end from a 4x4, or the track width will be wrong and 265 tires will rub the springs /forums/images/graemlins/eek.gif The spring perch widths are the same.
    The 14SF doesn't have sway-bar brackets. You will have to go without the swaybar, unless you're handy with a welder. The driveshaft for a 14SF is 1/2" shorter than it is for a 10-bolt. None of the ones he did got shortened, there was enough clearance.
  4. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    What do yo umean full width, unlike the 14 bff? The semifloater is just as narrow.
  5. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    Some light duty C2500's came with 6-lug 9.5's, and they were a couple of inches narrower than the 4x4 axles. I put one on my 93, and it bolted right on but the track was narrow. I ran 265's on stock wheels and they didn't hit but it was close.
