Has anyone installed 85+ grille & headlights in a '83 core support
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by IGOR, Sep 30, 2004.
  1. IGOR
    IGOR 1/2 ton status Premium Member
    May 16, 2000
    2,303
    19
    Damascus, OR
    Has anyone installed 85+ grille & headlights in a \'83 core support
    I got a screaming deal on a grille, headlights, and bezels from an '85 - which I thought would fit just fine in an '83 - nope - the core support is different around the headlight buckets - is there an easy way to modify this, or am I stuck either getting correct '83 bezels or the core support from the '85?
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    Re: Has anyone installed 85+ grille & headlights in a \'83 core support
    the only reason a 85 grille would fit into a 83 support is one is 2 lights the other is 4 lights. the 83-87,88 core supports are the same, same part number even, depending on 2 or 4 light.
    81 and 82 are WAY different.
    my 83 k10 had a 85 grille in it.
  3. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    My core support is from an 83 and my grill and bezels are from the 87. They fit perfect.
    My guess is (like stated above) one of them is single headlight and the other is dual.
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I installed a grill out of a 85 K5 in a 81 burb core support
  5. IGOR
    May 16, 2000
    2,303
    19
    Damascus, OR
    Okay - so yes I have a single headlight '83 - so has anyone done a single to a double?
    Jeff- it looks like you did it - how did it work?
  6. dyeager535
    26,975
    At some point, the screws that hold the grille in place on the bottom corners changed as well, and that metal piece that crosses right behind the bumper changed due to that as well.
    Not a major deal, but it IS different. I'm thinking that changed '84 to '85, but I'm not positive.
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    had to of changed 82 to 83 most likely,
