has anyone redrilled there spring packs?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by UNCLE CRACKER, Aug 15, 2002.
  1. UNCLE CRACKER
    UNCLE CRACKER 1/2 ton status
    Dec 29, 2001
    937
    PORTLAND OR
    I was wondering if anyone had redrilled there front springpacks to move the axle forward. If you have is there any problems that you have had from doing this?
  2. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    Have you considered using ORD's 'zero rate add-a-leaf' for this? May be easier, but it'll lift the front an inch.
  3. tipoil
    tipoil 1/2 ton status
    Jul 30, 2002
    222
    canada guebec
    it is realy hard to drill a spring (heat treaded realy hard)
    but it can be done but be patient!!!
  4. tRustyK5
    Jul 23, 2000
    36,184
    1,393
    E-town baby!
    Good quality sharp bits, some cutting oil and low speed...
    I drilled 10 leaf springs in about an hour with a 1/2" drill. It was much easier than I thought it would be, although the bits did need somewhat frequent sharpening.
    Rene
  5. UNCLE CRACKER
    Dec 29, 2001
    937
    PORTLAND OR
    does this cause the spring to crack or any other problems?
  6. tRustyK5
    Jul 23, 2000
    36,184
    1,393
    E-town baby!
    I was told as long as the new and old holes are still between the U-bolts that it shouldn't be a problem. I drilled the new holes 1.5" from the old holes.
    Rene
  7. UNCLE CRACKER
    Dec 29, 2001
    937
    PORTLAND OR
    I was just going to go up an inch so I should be ok
  8. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    why not just use the new ord offset ones /forums/images/icons/smile.gif
  9. UNCLE CRACKER
    Dec 29, 2001
    937
    PORTLAND OR
    I think they would cause unwanted axle wrap in the front. and I realy don't want to lift my truck anymore
  10. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    Not to mention having to move the hole in the spring mounting plate when you use the ORD ones. I saw Keiths rear ones and cant see makeing a hole in the weakest spot of the cast perch. Has anybody used these on the front?
    Depdog
  11. UNCLE CRACKER
    Dec 29, 2001
    937
    PORTLAND OR
    it would not bother me a bit to use them in the back. Im just not sure about the front. I know alot of people use them on the front with no problem. I would just rather redril the springs.
