Has anyone removed their ABS (1990)
Discussion in 'The Garage' started by BigCountryx, Oct 18, 2005.
  1. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    If so, any problems, lights? I would assume it is about useless since the disc brake swap and about to attempt a MC upgrade. Just would like to know what to expect ar what I should do. Thanks
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    Not the same app... But my 89 P/u has the ABS disconnected and the brakes work great! Actually it stops better than any vehicle I own!
  3. CK5
    May 19, 1999
    21,623
    701
    CO
    Same here, I don't think I have anything left of the ABS (1990).
  4. BigCountryx
    Feb 19, 2005
    519
    Gonzales, LA
    Should I expect any Dash lights?
  5. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I removed all the ABS stuff from my '90 and have no lights. The controller (located close to the M/C) was simply unplugged and removed, and then the hydraulic control unit was also removed and the lines replumbed.
  6. BigCountryx
    Feb 19, 2005
    519
    Gonzales, LA
    Thanks Guys, that's what I wanted to hear :wink1:
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    All my hydraulic stuff is still intact. But the controller was unplugged.
  8. CK5
    May 19, 1999
    21,623
    701
    CO
    Umm, I have no dash. :D
  9. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    I have a 91 and when the ABS unit at the master cylinder was unplugged, I got a dash light. On our vehicles, there is a switch at the tranfer case or 4wd shifter that switches off ABS when in 4wd. I'm planning on permanently jumping that switch on (ABS off). Just haven't had the time to track down the switch, but I see it on the shop manual wiring diagram.
    Eric M.
  10. BigCountryx
    Feb 19, 2005
    519
    Gonzales, LA
    Let me know if you find it.
  11. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    my 90' sub I switched out the 14sf for a 14ff out of a 76' 1ton and swaped on disc brakes and haven't had any problems with the brakes or lights coming on.
  12. BigCountryx
    Feb 19, 2005
    519
    Gonzales, LA
    :D :bow: :D
  13. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,015
    848
    Pinckney, MI
    did you hook the parking brake back up? I had an issue with mine after the swap, I didn't hook up the parking break, and the switch stuck.
  14. sweetk30
    Nov 1, 2004
    25,540
    539
    horseheads , ny 14845
    my 88 with the little box on the master only came on 2 times . each time was in the 1/4 mile burn out box full power brake burn outs.:D
  15. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    So did this ever happen, and if so what wire am I looking for?
    Tempted to just jumper the 4wd light switch, but I'd rather be able to turn the ABS on and off indenpendant of 2wd-4wd and still have the 4wd light work. I won't be the sole driver of my '91, gotta plan for the lowest common denominator.
  16. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    Why do you need to turn the abs on and off?
    Can't you just pull the bulb if you are ditching it?
  17. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    On for street use, off for dirt use. Washboard roads totally confuse the ABS computer. Result is the rear trying to pass you at every brake use.
  18. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    Why not install a power-to-the abs module interupt switch?
  19. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    So far I've not found that or a specific fuse that I could pull in the mean time.
    I like the 4wd light wire b/c what ever programming there is, is designed to accept that input. Turning the power on and off might work just as well, but it's the less clean approach.
  20. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    The 4wd switch wiring comes down from the dash under the carpet through the floor in the 85 and 87 K5's I have seen. Why not just splice in a switch to see what happens? Would have to be a three pole switch I would guess to get it to work right.
    Has anybody verified that the abs is disabled while in 4wd? I don't have one so I don't know. Since the trucks don't have communication networks, I would assume that the 4wd switch would be a direct input to the abs module. Try to find the wire there.
