Has anyone run Ford brakes on their Dana 60?
Discussion in 'The Garage' started by Flexy K20, Feb 22, 2003.
  1. Flexy K20
    Flexy K20 1/2 ton status
    Oct 22, 2002
    398
    Bay Area, CA
    If you change out the outer knuckles to Ford ones, Chevy's are 6 stud Ford's are 5, and the spindles and rotors you could run Ford brakes, which in this case are better. Ford's calipers are a little bigger and the are DUAL piston. I was curious if anyone has done this, because my friend just bought a Dana 60 and it came with this. Is there anything else involved? How did it all work out? Thanks
    -fLeXy K20
  2. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    Got HiPin 60 with dual piston calipers and love it.Best the brakes have ever been on my rig.Some Ford 44s with 8 lug rotors have the same brake setup on them.I have one of them also for a future project. /forums/images/graemlins/thumb.gif
  3. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Yep, I'm running an HP Ford Dana 60 as well with the dual piston calipers. The brakes are quite impressive /forums/images/graemlins/thumb.gif. Believe it or not but my 8k pound truck actually stops quicker and safer than it did with the stock tires and the stock abs system functioning /forums/images/graemlins/shocked.gif. Nothing like 4 locked up 40" tires to bring you to a hault /forums/images/graemlins/thumb.gif
    The only downside to the Ford outers is that it costs a whole lot more to convert to 35 spline. I found a kit for around 595 and the parts for around 450... Compared to around 250 for a GM 60...
    WMS 35 Spline Kit
  4. ZonkRat
    Jan 16, 2003
    1,003
    I want your high steer arm for crossover.Where'd you get it and how much.I'd like to do whole high steer setup later on 88SWB SFA.This is first time I can lock tires on pavement since going to 35s years ago.Also have 10.25 dually axle in rear.The drums pull of without tearing down bearings and help to keep mud out of drum brakes.Also has more clearance than shaved 14B. /forums/images/graemlins/thumb.gif
  5. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    It's the arm from ORD
  6. ZonkRat
    Jan 16, 2003
    1,003
    Thanks.Can't afford to do this now,but,planning on doing it later.Just gotta save the dough. /forums/images/graemlins/thumb.gif
  7. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    I'll probably have my arm for sale here in a few months if you haven't got one by then... I'm making my own knuckles with integrated arms...
  8. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    The Ford 1.25" rotors are known for cracking & warping under heavy use. The dual-piston caliper won't fit a 1.5" rotor. The Ford calipers sometimes have one piston jam up too /forums/images/graemlins/tongue.gif
    I'd consider the dual-piston an upgrade on a Dana 44, but not on the 60
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    I believe Dan (KRAZIE87K5) is running Ford brakes on his GM D60. /forums/images/graemlins/wink.gif
  10. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Two things to remember about Ford knuckles/spindles:
    1. It is harder to 15" wheels on.
    2. You cannot fit a D70 outer in the Ford Spindle. So, no 35 spline.
    Number 1 may not matter to a lot of people, but number two should.
    -- Mike
  11. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Tx Mudder, read my 2nd to last post. At the bottom you will see this LINK
  12. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    $595 a set, versus much less for spicer units.
    That is an OK price if you want alloy stub shafts, but if you don't then it's $$.
    Nice to know they make them though.
  13. ZonkRat
    Jan 16, 2003
    1,003
    PM me about it when you're ready to get rid of it. /forums/images/graemlins/thumb.gif
