Has anyone seen this
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ledfoot, Dec 16, 2000.
  1. ledfoot
    ledfoot Registered Member
    Dec 8, 2000
    16
    My "new' 82 Blazer has water in the oil. So it looks to me like a blown head gasket. I pulled the heads off today and I found that the water port in the intake manifold is completely blocked near no.7 and almost completely blocked on no. 8. Help. What causes this and how bad is my engine?
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i would guess what caused this was no one ever flushed it very often. do a good flush and fill repetidly till all comes out clean
    s.smith 77blazer lookin 4 mud
  3. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    What are they blocked with? Rust? Sludge? RTV?
    Smitty
  4. Gopherkiller
    Gopherkiller 1/2 ton status
    Aug 14, 2000
    188
    Hey do all that, but remember you got oil in your water. Don't put it back together without finding something. Look at the head gskts close. Look everywhere for cracks. Then go have a beer. Gopherkiller
  5. ledfoot
    Dec 8, 2000
    16
    Smitty: It looks like calcium or hard water deposits. When I first looked at them I thought it was gasket material, but then I took a screwdriver and punched throught it. It was just like calcium deposits on a water faucet.
  6. bart
    bart Registered Member
    Mar 15, 2000
    69
    Eastern PA
    This is testament as to why you should use distilled water in your antifreeze mix and not to use tap water...especially if you have really hard water in your area. Seriously, it really helps reduce the mineral deposits in your cooling system to do so. I've also switched my vehicles over to dex-cool (red) antifreeze for the additional corrosion protection that it offers over conventional green antifreeze.
    bart
  7. Channing74
    Channing74 Registered Member
    Dec 14, 2000
    77
    Southwest louisiana
    Quick reminder .... being in the automotive business i have seen what mixing the 2 antifreezes can do to a system ...... dont do it!!!!!!!!! As for the distilled Water... Very Good Call .... Everybody Should Only Use Distellied Water In The Coolant System.
    Bigger Is Better
    Channing74
