Has anyone swapped in a NP205 into 1990 or newer GM?
Discussion in 'The Garage' started by CK5, May 3, 2002.
  1. CK5
    May 19, 1999
    21,623
    701
    CO
    Just stumped on what to do with the VSS.
  2. therobzilla
    therobzilla 1/2 ton status
    May 15, 2001
    1,307
    Gilbert, AZ
    Steve,
    I have a 72 First gen with a 92 camaro motor under the hood. I use a 4 pulse generic vss with the system and it worked ok, had to tell the computer what it was but that was a chip programming issue.
    The company I bought the vss from was Arizona TPI, and it had a special adaptor on it for the 205. Works like a champ and no leaks.
    My ideas.
    Rob
  3. CK5
    May 19, 1999
    21,623
    701
    CO
    Hmmm, I can find stuff to put new motors etc in old rigs but not old stuff in new rigs. I will check it out though, do they have a website?
  4. CK5
    May 19, 1999
    21,623
    701
    CO
  5. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Try www.jagsthatrun.com - they have many choices on VSS - I bought one from them for my '79 w/TPI setup - $70. Mine went on the cruise control under the hood, not sure what a 90 CC is like, but they have them all. And.........they know their stuff...........
  6. CK5
    May 19, 1999
    21,623
    701
    CO
    I called them before, they couldn't help me. Keep in mind your speedo is mech and mine is elec.
  7. BurbinOR
    5,829
    Oregon
    True, but mine is not anywhere near the speedo, it is on the cable..............guess you don't have a cable? Either way, I'm surprised they don't have one for the output on the transfer case, they told me that was my other choice.
  8. CK5
    May 19, 1999
    21,623
    701
    CO
    I have no speedo cable, just wires.
  9. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Give Street & Performance a try, their number is 501-394-5711. I would talk to Mark, he is the owner and is very friendly and knowledgable. They are located in Mena Arkansas. http://www.tunedport.com
  10. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    Steve,
    I went through all this when I put the first doubler in my 90 Blazer. There are 91 4-door dually trucks out there with the 205 and VSS, but very few of them. There were about 4 of them at work when I was out in San Diego. I got the part numbers from them and tried to get the tailhousing from GM, but I was unable to locate one. I even went through Parts Mike nd he could not locate one either. I tried all the big speedo places and nobody had anything that would work either, so I wound up machining the tailhousing on my 205 and put the gear from the 241 in there.
    Russ
  11. Donovan
    Donovan 1/2 ton status
    524
    Arvada, CO
    Steve call me at work this morning if you want to 303-423-6152. I can machine the tail housing like Russ said and I have a 241 VSS gear here all ready. Let me know.
  12. CK5
    May 19, 1999
    21,623
    701
    CO
    Awesome, see you on Monday.
  13. CK5
    May 19, 1999
    21,623
    701
    CO
    Russ, just curious, do you have the part number? Also, did GM tell you that it was discontinued?
  14. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    Steve,
    It has been a couple of years, so I am not sure if I still have the numbers floating around. I will look for it. GM did say that the part was discontinued and I could not find one on a shelf anywhere.
  15. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,953
    248
    Released from Pueblo, told I belong in Southpark
    Steve there was a shop in Colorado Springs a few years ago that helped me with some speedo issues. If it is still open maybe they can help. The Speedo shop was its name then.
  16. CK5
    May 19, 1999
    21,623
    701
    CO
    Thanks, Donovan is going to fix me up.
  17. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    Sorry to dig up old stuff...but have you been able to get this done yet? I may be looking into doing this myself so I was curious as to the outcome.
    Just for clairification - when you are referring to machining the tail housing, are you modifying it for the external switch or for an internal gear?
    Thanks for all the good info!!
  18. CK5
    May 19, 1999
    21,623
    701
    CO
    Yep, Donovan here in Denver (Ram grinding) can now do them, you have to get a tone ring (40 pulse gear) from the dealer (20.00) and have it taken down a little depending on what kind of 205 shaft you have etc..
  19. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    I don't know if you saw my other post but this should also work for you.
    http://www.dakotadigital.com/Detail.cfm?Category=106&PartNumber=SEN-01-1
    I have a 205 and a digital dash and this works for me. Not sure if the pulse interval is the same as stock GM. My dash allows for adjustment (i.e. changing tire size and/or gear ratios) for fine tuning. I would assume you are not running stock/gears or tires so adjustability will definitely be an issue.
