Has anyone used the cadi calipers and liked them?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by djohnsn, Jun 23, 2002.
  1. djohnsn
    djohnsn 1/2 ton status
    327
    Plano, Texas
    I have read mostly negative things about the cadi calipers. I am doing a disc swap on my 14-bolt ff and need to retain the e-brake, so I was planning to use calipers from a 77 cadi. I would like to know if people using this setup are happy with it or not.
  2. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    what kind of negative stuff are you hearing ?
  3. djohnsn
    327
    Plano, Texas
    I have heard that the e-brake does not hold very well. I have also heard other non-specific complaints about them - just "they don't work very well". I know that some have switched from the cadi calipers to the d44 calipers, but I don't know the specific reasons.
  4. topless1tonk5
    topless1tonk5 Registered Member
    Dec 10, 2001
    98
    littleton co.
    they work well if they are set up correctly.
  5. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I run them and they work very well. My descents have never been easier. I have not hooked up the e-brake though so that could still be an issue.
  6. BigBadCad
    BigBadCad 1/2 ton status
    Dec 18, 2001
    109
    minneapolis, mn
    I've been running a set for about six months now without a problem. The ebrake does work but it doesn't have the same holding ability the drums did.
  7. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    when I do my conversion I have to retain the ebrake also...doesnt matter if it works... I keep the truck in gear anyway.. but NJ law is ebrake has to work....
    /forums/images/icons/grin.gif
