Has anyone used the tornado air cleaner things
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by pplblazerdude, Jun 6, 2003.
  1. pplblazerdude
    pplblazerdude 1/2 ton status
    Jul 18, 2002
    242
    Kingsport, Tennessee
    I was wondering if any has had experince wuth them cause i need fuel economy but i love the k5 so i eat the cost of gas. I was wonder does it help and if it does how much and how.
    Thanks,
    clint
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    My buddy used one on his Jetta and got worse MPG. I think they are a waste of money. Just my .02 get a good exhaust and a K&N keep your motor tuned up. It will never get great mileage it's a V-8.
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    did i hear "marketing scam"? yes... they're crap... i work for a ford dealer... a lot of trucks came in right after those things came out... bucking, running lean, etc,, nothing but problems... wouldnt put one on my truck...wouldnt reccomend you do it either..good tuned motor, decent flowing intake and exhaust is your best bet
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Like the others said...."waste of money." /forums/images/graemlins/tongue.gif /forums/images/graemlins/rolleyes.gif
  5. BlazerWheels
    BlazerWheels 1/2 ton status
    Feb 13, 2003
    587
    California
    Boy they can sure sell anything, can't they.
  6. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    It spins and that is all it does. I got one for cheap way back when people started asking about them to test it out. I still have it installed. It may suck, but it's staying, I'm getting my moneys worth dang it... /forums/images/graemlins/rotfl.gif
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    There's a sucker born every minute!!! /forums/images/graemlins/wink.gif /forums/images/graemlins/deal.gif /forums/images/graemlins/thumb.gif
  8. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I actually saw a test of one of those things on a Mustang 4.6. They dynoed it before and after and it made LESS HP and torque with the thingy on it. </font>
  9. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Sweet! You mean I can pay money to have my HP decreased! That is so cool. /forums/images/graemlins/rotfl.gif
  10. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    That is what I was thinking, anyone have their 1-900 number?
    John
  11. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
  12. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    The whole idea to make more power is to straighten out the air flow.
    Not swirl it all up.
    Velocity stacks, straight runner intakes and K&amp;N filters, all smooth and even out the air flow. These are proven performance mods.
    I cant see how those Tornados even work on later model cars. Late model FId cars need a straight smooth airflow past the MAF sensor to get proper readings. Thats why GM has those honeycomed screens in the TBs. They are called "Air stream straightners" They give the MAF sensor nice clean air to read.
    Seems to me Adding one of those Tornados will only hurt performance.
    But hey they sell gas line magnets and little pills you put down the oil fill hole that instantly rebuild your engine. /forums/images/graemlins/rotfl.gif
    P.T. Barnum said " There's a sucker born every minute"
    But he said that a long time ago. I think there is more now.
  13. Ditchdigger
    Ditchdigger Registered Member
    Mar 11, 2001
    96
    The Great Midwest
    DON'T, that is a bunch of CRAPOLA!
  14. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    What????
    What did I say that is a bunch of crapola????????
    Are you saying GM, K&amp;N, Aftermarket manifold manufactures ect, dont know what they are doing ?????
    Do you have info that says adding turbulance to the air flow makes better power and improves economy? If you do I I would sure like to see it.
  15. Ditchdigger
    Mar 11, 2001
    96
    The Great Midwest
    DON'T, I believe Those Tornado things don't do anything.
    as many engines I've worked on I would see more bad than good in them. I think you misunderstood me Thunder, I was posting to original question.
  16. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    Sorry DD /forums/images/graemlins/blush.gif I thought because you responded to to my post you were talking about me LOL.
    As for getting better milage:
    Do a through tune up. Plugs wires cap rotor fuel filter. Check all vacume lines for breaks or holes.
    with the TBI you can set the base timing a few degrees over 0 without problems and get a little better performance. Do not excede 4 degrees BTDC or it may ping or throw codes.
    Get a free flowing exhaust. if you dont have smog tests loose the cat and plumb single 3" pipe with a good muffler all the way back. Headers wont help much with gas milage and are a needles expense if gas milage is your goal.
    Check out this stuff:http://www.turbocity.com/TBIPowerMain.htm
    Get the air flow enhancer it works its worth the 40 bucks.
    The TBI spacer may also help because it builds torque
    A better coil like the MSD blaster helps MSD makes a direct plug in coil for TBI trucks.. Then You can open up the plug gap some. I run my plugs at .050" But it best to experment to find out what works best for your rig.
    Use synthetic lubes in engine and drive train.
    Check air inflation in your tires. The more pressure you can run without wear problems the better milage you will get.
    The best mods for fuel milage are ones that build low end torque. the less you have to press the gas pedal to move your truck. The less gas you will use
    I run all the mods I have listed on my TBI 350 and get 18 mpg at 75mph on the freeway I have got as high as 20 but I Cant Drive 55 mph
    I get 15 mpg average around town if i can keep my foot out of it.
  17. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    i thought about getting one of them.. but then watching the info mercial i realized the guy said... " creates a vortec " well duhhh... my 1996 gmc jimmy has a 4.3 vortec motor... so i think that my intake already does this!!!!!! and most add ons like that are junk..... glad i didnt get one after all....
  18. SCOTTS_4X
    SCOTTS_4X 1/2 ton status
    Mar 22, 2002
    129
    Modesto CA
    What????
    actually, I know a few wngine builders that will port an intake manifold and heads, but not fully polish becuase if you leave a little bit of a rough surface it helps with fuel atomization and thus increases power, miileage, etc. just thought I would throw that in there.
    -Scott
