Hates starting when hot.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DUKE, Mar 16, 2002.
  1. DUKE
    DUKE 1/2 ton status
    Nov 14, 2001
    879
    Davenport Iowa
    Ok im not sure what or why but if you do please share. When ever i turn off the engine for just s few min, say to get gas, she is a pain to start turns over really slow. Somtimes refusses to start at all, some times only after a try or two. When i let her cool down she starts right up. Pretty much in the dark here.
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    try adjusting the timeing
  3. Stomp
    Stomp 1/2 ton status
    Feb 23, 2002
    168
    Hill Air Force Base Utah
    yep sounds like a timing issue
  4. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    Does your truck have headers?The stock Gm starter solenoid is prone to not operating when it gets hot.There are a couple fixes...1) installa remote solenoid, 2) insulate the solenoid from the exuast, or 3) easy fix...pour some cold water over the solenoid everytime you want to go somewhere!LOL!!!
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    yes both issues would cause this a over heated starter or timeing
  6. tRustyK5
    Jul 23, 2000
    36,166
    1,363
    E-town baby!
    My timing is spot on, I run a remote mounted solenoid, and all new oversized wires. I even have a separate 'starter' button so I can spin the motor and then turn the key on to start it. My truck will still not start when hot.../forums/images/icons/mad.gif Yes I have headers.
    I think the starter itself is just geting old and weak though. I'm going to try one of the new gear reduction starters Chevy used in the newer trucks and see how it does then.
    Rene
  7. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i would like to try one of those as well /forums/images/icons/smile.gif
  8. DUKE
    DUKE 1/2 ton status
    Nov 14, 2001
    879
    Davenport Iowa
    How about a heatsheild of some sort?? Think that could work
  9. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Could it be vapor-lock?? My truck was doing the same thing right after I installed my new exhaust system. Turns out the passenger side cat was too close to the fuel lines. So I fabbed up a heat shield that goes around the cat and one for the frame.
  10. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    Get yourself a starter shield form summit for 20 bucks... I had the same thing... now have the remote start and heat shield... not one problem... now that it's shimmed right too that helped... takes alot to turn a 468 c.i monster...
  11. tRustyK5
    Jul 23, 2000
    36,166
    1,363
    E-town baby!
    I'll prolly put a shield on a new starter. This one is as old as dirt and has been apart at least four times in the last 2 years. It grinds at least 1 out of every 10 starts.../forums/images/icons/crazy.gif
    Rene
  12. reddog64
    Nov 9, 2000
    3,325
    I went through four new starters till i gotta good one and shimmed it right on the 454...
    Thank God for lifetiem warranty /forums/images/icons/smile.gif
    I'll see if I can find a starter for you rene... I may have another good one...
  13. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    I have had problems with this and look at your grounding wire is it on a good steel connection like the block on the bell housing is not good for example but all the above advice is all very good
  14. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Assuming your wiring is all good (there is more to good connections than just heavy guage wire) it sounds like a starter issue. It's called heat soak. I had my starter reworked at a local shop. They beefed it a little. I'm running a factory style soleniod with heatshield. I also have 1/0 positive AND ground wires hooked to a 950 amp battery. Remember that electricity flows from negative to positive. The gear reduction starter should solve any problems as long as recieves ample current.
  15. denver75k5
    denver75k5 1/2 ton status
    May 15, 2001
    1,017
    Somewhere In The Woods
    If you run a edelbrock carb, thats your prob. Mine always did that, they dont like heat at all.
  16. DUKE
    DUKE 1/2 ton status
    Nov 14, 2001
    879
    Davenport Iowa
    OK, I bought this heat sheild at napcheckerzone supposed to fit, didnt but managed to work it anyway. First results seem to improve, but i will have to drive it for a good long time to make sure. Seems to start better over all after being cleaned up and tightend up, Thanks for all the advice.
