Haunted Wipers
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Smitty, Nov 2, 2000.
  1. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    The wipers on my 82 will cycle once everytime I start the engine. Figured I'd ask if anyone has run into this before I break out the testlight.
    Smitty
  2. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    I had that same problem on a 90 S-10 Blazer that my wife had. Then it started to do it when you turned the steering wheel a certain way. She would never let it sit in the driveway long enough to work on and in 96 we traded it in. Never could find the source. I figured that it was something in the stering wheel that had chaffed through a wire and letting the park ground make a momentary contact. This is the only thing that I figured would cause it.
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    My 84 started doing the same thing- it wasn't much later that I experienced a cloud of blue smoke and a fancy repair bill. To confirm Wheels suspicions, the coating on one of the wires in the column had been rubbed off at the tilt pivot point, and basically trashed the whole harness once it lit up. To compound the matter, I also have cruise control on the signal arm, which of course joined in on the meltdown action.
    So take my advice and get in there and look for the short, before the harness burns up.
  4. Smitty
    Sep 1, 2000
    999
    Crestview, FL
    My wiper controls are on the dash. I'm not too sure how something in the column could be causing the problem.
  5. CBLAZER81
    CBLAZER81 1/2 ton status
    Mar 3, 2000
    281
    Milliken,COLORADO
    Mine were acting up awhile back.I went to the junkyard and got a new/different switch.They have a printed circuit board in them and mine was worn out and loose.Good luck.
    Chuck
    81 Blazer
    Colorado,USA
  6. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Your wiper motor has a park switch which runs off a cam, and relay of sorts when you turn off the wipers it is supposed to return the wipers to the off position. I believe the contacts have gotten out of adjustment so when you power up the truck it thinks you have just shut off the wipers causing the blades to "repark" themselves.
  7. Smitty
    Sep 1, 2000
    999
    Crestview, FL
    I was thinking along the same line. Pulled the switch apart and cleaned the electrical contacts but they didn't look too bad. At least the intermittent wipers work a little better now. I'm headed for the park components next since this only happens when I start it up.
    Smitty
