Have 400/203 right now, what will it take to make it 400/205?
Discussion in 'The Garage' started by dawson444, Jun 6, 2003.
  1. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    I have a 400/203 right now, I also have a 205 for a TH400 laing around. Is it just a matter of getting the 400/205 adapter and bolting everything together and getting driveshaft lengths changed? Will the 400 output shaft length and spine count be ok? Anything else? Thanks!
  2. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Spend the money on a Doubler - you are nearly there! It's well worth it. I dont think I know a dissatisfied Doubler owner. /forums/images/graemlins/thumb.gif
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    400 output for a 205 is different, so is the adapter. It won't cost much more for a doubler, don't waste that rare 203/400 combo by converting it to a 205... If nothing else, sell it and buy what you want, then pocket the difference.
  4. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    What about the output is different? I just don't have the money for the doubler right now. I would hold onto everything and go back later and do it, just not now. My 203 won't stay in gear and it is pissing me off. I was thinking about twin sticking the 205 and putting it in there as a fuly functioning T case until I do the doubler. Now its looking like that isn't going to happen. Can anyone shed some light on where to get a rebuild kit for a 203? Thanks!
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    The output lengths are different, you have to completely disassemble the tranny to swap them. Also, the 400 205 is not common or cheap, though common 205s can be modified for the right input to be installed. The adapter is also hard to find. If the 203 is popping out of gear, it could be just the shifter. Talk to (PM) Gimreaper since he is our resident 203 evangelist and expert...
  6. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    Already played with the shifter. That isn't it. Thanks for the help though!
  7. seanschevy
    seanschevy Registered Member
    Dec 18, 2002
    29
    NJ, USA
    if u want to sell that 205 ever give me a email. I could really use it. Seandkd@aol.com thanks and good luck hope u work something out
  8. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Dawson, the 205 you have will not just bolt to the trans even with changing the adapter. The th400 uses a totally different output shaft for the 203 then the 205. You will either need another output shaft installed in the trans or get the correct trans.
  9. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    i'll take your 203.
