Have 6" rear Skyjackers 1 3/8" or 1 1/2" bushings?
Discussion in 'OffRoad Design' started by Zepplin, Jul 1, 2002.
  1. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    Have 6\" rear Skyjackers 1 3/8\" or 1 1/2\" bushings?
    Steve,
    I sent you a message using your websites comment section.
    I just wanted to let you know that I'm ready to order:
    GU38010
    U8003
    GU38003 or GU8002 depending on bushing size
    Thanks,
    Zepplin
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Re: Have 6\" rear Skyjackers 1 3/8\" or 1 1/2\" bushings?
    Those bushing sizes you listed have nothing to do with the leaf springs themselves.
    Those sizes you listed have to do with the shackle which bolts to the frame and holds the spring to it.
    GM has different size shackle bushings to use.
    The older trucks use the popular 1 1/2" i.d. shackle bushings.
    '81 on up use the 1 3/8" i.d. shackle as their "common" size.
    Be aware that K30's used three different size bushings!! /forums/images/icons/shocked.gif
    They use either the 1 3/8", 1 1/2", or 1 3/4" i.d. bushings.
    The best thing to do is to get the shackle and measure the hole, WITHOUT the bushing and sleeve which is pressed into the shackles hole.
  3. Zepplin
    Aug 29, 2000
    920
    Bay City, MI 48706
    Thanks K30.
    I will go out and measure the size of the bushings.
    Later,
  4. Stephen
    Sep 15, 2000
    4,228
    142
    Carbondale Colorado
    A '74 should use the GU38002 kit, 1 1/2" shackle bushings. Always best to measure to be sure. Shipping replacement bushings around is a major pain for all involved.
    Give us a call or with part #'s you can easily use our online form.
