Have a ? about brake master cyl.
Discussion in 'The Garage' started by BILLY RAY, Aug 13, 2003.
  1. BILLY RAY
    BILLY RAY 1/2 ton status
    Dec 8, 2001
    1,319
    Austin, Tx.
    OK! Installed the caddy calipers in the rear and think I may need a por. valve but don'y know for sure just yet. Now what I really need to know is If I install a 1 ton brake master cyl. on the truck would it give me a longer pedel throw and push more fluid to the rear calipers or anything like that. If so what year master cyl. and can I use the same booster I have now. (just extra info. I just pulled off the dana 44 calipers to install the caddy ones)
    Also looking for any pics. they may have how the e-brake cable is hooked up to the caliper or brackets to hold the cable.
  2. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    ok, I'm headed over to the chevy dealer today and will ask about the older motorhome master-cylinders that were on them with 4 wheel-disks, I have been told that it was a 1-ton truck chassis and like I said had 4 wheel-disk...keep your fingers crossed... /forums/images/graemlins/thumb.gif
  3. TONYP
    Aug 13, 2002
    2,116
    so cal
    just talked to the chevy man...
    part # 1257225 por. valve...
    it's from a P30-60 truck that had 4 wheel disk brackes, they didn't have one in stock for me to look at but the guy said it will work... /forums/images/graemlins/thumb.gif
  4. Hardcore
    Hardcore 1/2 ton status
    Apr 25, 2003
    458
    New Orleans, LA
    /forums/images/graemlins/thinking.gif Keep us updated /forums/images/graemlins/deal.gif /forums/images/graemlins/ears.gif
  5. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    i dont think a one ton master cylinder will fit on a half ton booster..we tried it and it wouldnt go..pushrod wasnt anywhere near long enough and it wouldnt seal right..
  6. TONYP
    Aug 13, 2002
    2,116
    so cal
    this is the proportioning valve only... /forums/images/graemlins/thumb.gif
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    The push rods can be swapped.
    On the prop valve, I'm not sure that will work out to be ideal. The prop valve not only controls flow and "take up", but also pressure balance. The correct balance is going to depend not only on the mechanism (specific caliper, disk vs. drum, etc.) but also on the weight distribution (and it's affect traction).
    I'm no expert, and I don’t speak from experience, but that's what comes to mind...
  8. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    I put a 1 ton MC on my 82 K5 and my 86 K10 with no mods to the booster or pushrod.
  9. Confedneck
    Nov 1, 2002
    5,236
    hmmm we tried it on an 84...and my 86 has the same booster m/c as the 84 does...
  10. outlaw612
    Feb 11, 2001
    2,342
    It doesnt look like it will work, but just bolt it on and everything will work. Ive been running the one on my 86 for about 1 year now.
  11. Confedneck
    Nov 1, 2002
    5,236
    i think the one we had was for hydroboost..
  12. outlaw612
    Feb 11, 2001
    2,342
    Yep, that could have been a problem /forums/images/graemlins/blush.gif
