have a problem blazer doesn't stop running when turn the key to off *DELETED*
Discussion in 'The Garage' started by scorpio, Aug 16, 2002.
  1. scorpio
    scorpio Registered Member
    Oct 6, 2001
    26
    dallas,tx
    have a problem blazer doesn\'t stop running when turn the key to off *DELETED*
    Post deleted by scorpio
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    Re: have a problem blazer doesn\'t stop running when turn the key to off
    sounds like you have a wire crossed someplace /forums/images/icons/shocked.gif
  3. scorpio
    Oct 6, 2001
    26
    dallas,tx
    its been running fine until yesterday
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    could still be a wire crossed that just yesterday worked itself into a position to ground out or touch another wire if 2 wires are rubbing together they will eventialy rub enough to wear through the outer coating and make a conection with each other just something to look for
  5. scorpio
    Oct 6, 2001
    26
    dallas,tx
    thanks i'll take a look. i wasn't thinking about it that way.
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    no problem hope you get it found soon and keep us posted when you do find out whats wrong
  7. scorpio
    Oct 6, 2001
    26
    dallas,tx
    dug around and couldnt fine anything yet. will do some more digging around tommorow. i need some wire diogram.
  8. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    the Haynes manuels have a decent wiring diagram in them
    dude, I don't wanna scare you, but your truck won't cut off when you turn the key: You ever read the book/seen the movie "Christine" by Stephen King? Might wanna watch stepping in front of it for a while /forums/images/icons/wink.gif
  9. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    It doesn't take much current at all to keep the ignition system working. Your profile doesn't say what year your truck is, but I'm guessing that it doesn't have fuel injection. If so, start looking for other electrical problems. That can help you find why the engine won't shut off. Vehicles use very strange wiring, to minimize the number of wires that they have to use when building them.
    Back when my '75 had the stock engine, I backed into the driveway one day and shut off the key, but the engine kept running. In my case, if I took the trans out of reverse OR let my foot off of the brake pedal, the engine would finally shut off. I had noticed on the way home that one of my turn signal indicators in the dash was glowing, ever so slightly, all the time. Turned out that a bad ground inside the left rear tail light assembly was causing the problem! /forums/images/icons/shocked.gif WIthout that ground, when both the brake light switch AND the backup light switch were on, they setup a path that would provide power to the coil, thus keeping the engine running even with the ignition switch off. I never would have thought to look at the back of the truck to fix a problem like that if I hadn't noticed the turn signal indicator... /forums/images/icons/cool.gif
  10. scorpio
    Oct 6, 2001
    26
    dallas,tx
    thank for the help everyone i'll check on all ya'lls insight. to answer the question the blazer is a 1985.
  11. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    does it just sputter when you turn the key off or keep actually running, if it just sputters couldnt that be something with the Timing?
  12. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    what does it mean if it is dieseling. thats what mine does, but it only does it sometimes. sorry to get off key.
    thanks
    nathan
  13. scorpio
    Oct 6, 2001
    26
    dallas,tx
    dieseling could be cause by the timing been off or the carb maybe needing adjustment
