Have a stud with a nut on it, need to get nut off. Please help!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dawson444, Aug 27, 2002.
  1. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    I have a stud for my steering block on my D60.The stud has a nut on it that I need to get off to put the block on it. (got block used) Any tips on getting the nut off the stud? When I turn it the stud turns too. I have thought about using red loc-tight (blue doesn't hold), but I am worried about if I will be able to get the stud out when I go to cross over and ditch the block.
    BTW- vise grips didn't hold the stud. Plese help. Thanks!
  2. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    Had same problem, used big vise!!!! Clamped real carefully but tight as all hell! /forums/images/icons/cool.gif
  3. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    dremel too with a cutting disk. just hit the nut paralell to the bolt on opposite sides.
    carefull of the threads. once you are close to the threads, grab it with pliers an yank. it will come off.
    grant
  4. BIGRIG
    BIGRIG 1/2 ton status
    Feb 29, 2000
    488
    Independence, MO
    They sell a tool called a nutcracker..cheap like 5-10$..go to any parts store and ask for one. I use mine all the time especially with old cars in the rust belt. Cracks the nut right off and goes to 1/2 in.
    Chris /forums/images/icons/cool.gif
  5. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    oh yeah.. i got one of those to... but i have never used it... wonder why... glad i got it as a gift...
    grant
  6. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    Anyone have an opinion on the red loctight, putting it on the bottom of the stud? Will I be able to get the stud out later? Thanks!
  7. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Try a nut splitter.
    Bill
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    heat required with red loctite, dont use it
    cold chisel the nut until it cracks then spin it off
    should take less then 5 minutes
