Have a transmission question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by stump_puller, Aug 24, 2004.
  1. stump_puller
    stump_puller 1/2 ton status
    Apr 5, 2002
    871
    135
    Corbin, Kentucky
    I know it has been covered before But I need to know your guys opinion on what I should do. my current 700r4 is getting very slushy when it shifts.
    So what do I do?
    1. Get my current 700r4 rebuilt
    2. Put a shift kit in the 700r4 and hope for the best.
    3. I currently have a turbo 350(needs to be looked at) just swap it in and go.
    4. Spend a few dollars and get a turbo 400
    5. 4L80 out of a trans am modify to fit 4wd.
    My future plans will be a 6" lift 38"TSL Radials. A gen2 doubler. D60front and rear.
    Any input would be great.
    Don
    /forums/images/graemlins/truck.gif
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Looks like a TH400 would be the best choice of the bunch
  3. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Yepp, if your going to do a doubler I'd put in a TH400
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    So what do I do?
    My suggestions:
    1. Get my current 700r4 rebuilt - good idea especially if you like the steep 1st gear and OD
    2. Put a shift kit in the 700r4 and hope for the best. - if your tranny is already sloppy, this would probably make it worse
    3. I currently have a turbo 350(needs to be looked at) just swap it in and go. - this may put you in the same place you are with your 700
    4. Spend a few dollars and get a turbo 400 - good upgrade for strength but you loose some ont he first gear and no OD
    5. 4L80 out of a trans am modify to fit 4wd. - T/A's come with 4L60E's which is an elec. 700r4. 4l80's come in trucks. There was someone on the board that was selling rebuildable cores for around $200...
    Hope this helps!! /forums/images/graemlins/thumb.gif
  5. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    The question is if you need overdrive. What gears with the 38's?
  6. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,086
    487
    Grand Rapids area
    I agree with Mike, but I have one addition: The 4L80E is strong and has O/D, but you will have to come up with a stand-alone transmission controller for it, which is bound to be expensive and complicated. Really, the best way to swap one of these in is to take the whole engine and transmission out of a late model wreck.
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    personally i would go with a th350 sinc eit will basically fall in place of a 700r4
    all up to you though andx how much you like spending money and hunting down parts that youre gonna need
