Have Blazer....Now What--
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TallCowGirl, Jul 8, 2000.
  1. TallCowGirl
    TallCowGirl Registered Member
    May 20, 2000
    35
    New Mexico
    Hi Blazer Fans...I finally got to have a good look at my new 73 K-5 Blazer. It´s going to need a lot of little things done on it. For starters, the wiring and seats are a mess. If you can help with the following questions, please let me know:
    (1) Where can I get a COMPLETE wiring diagram from for a 73 K5 Blazer? I need to fix the wires going to the ignition switch so that it starts when you turn the key. It´s currently hot wired with a starter button.
    (2) On what point on the engine block is the negative wire from the battery supposed to go(a la from the factory)? The guy I got it from put it on the alternator bracket. That doesn´t seem right to me, but if it´s right, let me know.
    (3) The truck is lifted with springs in front and riser blocks in back (mabye 1.5¨to 2¨ in height) for 35¨ x 12.50 tires. I´ve noticed rub spots on the front quad shocks. What´s a good fix for this?
    (4) The truck won´t track straight going down the road and wanders. I don´t know much about steering, but from asking around, I´ve been told that I need a new steering arm. What should I get to fix the problem?
    (5) Are 73-75 Blazer/Jimmy seats specific to those model years or will seats from other full size GM trucks fit?
    The Haynes manual for this truck has good basic info but it is limited on specifics. These are the basic problems I need to fix on my Blazer to get it going.
    Thanks,
    Diana
  2. det45
    det45 1/2 ton status
    May 23, 2000
    112
    San Antonio Texas
    Sounds like you have a real project on your hands. What I would do first is try to hook up with a off road shop in your area for advice. You will find that most 4x4 nuts hang out there and would be willing to give you good advice on what you will need done. Most people in those shops can direct you to someone for advice. Also I would try to get most of your parts from a wrecking yard as long as they give you a warranty. And of course you can get a lot of info from this fourm too......Where are you located?..........Det45
  3. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    <font color=blue>I have a Haynes pickup manual that shows a very nice ignition schematic for '81 and up. They are all very similar. I can make copies and mail or fax them....sorry no scanner.</font color=blue>
    <font color=blue>That's where my '74 ground wire is....works great.</font color=blue>
    <font color=blue>You need at least 4 inches of lift for 35's......new front springs and taller blocks for the rear.</font color=blue>
    <font color=blue> I'll stick to the same answer from the 2WD section.....I would take it to a front-end shop for alignment and to check for worn parts. Steering is quite important and if you don't know much about it I would seek out a shop. There are too many varibles to give an accurate "fix" without seeing it.</font color=blue>
    <font color=blue>Just about any model Blazer seat will work and anything else can be "adapted". I got a great deal on some grey velour seats out of some little car at a wrecking yard and made them work.</font color=blue>
    Michael [​IMG] http://jmartin.net/parker/goose.htm
  4. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    As for #1, I have a factory service manual for my '79. If they are anything similar, I too could copy and send the schematics to you. Pages and pages of them. I would suggest getting your hands on a factory service manual. They're pricey at about 80 bucks, but worth it since that's what the mechanics use. HTH
    Bryan
    [​IMG][​IMG]
    Durant, Ok
    '79 Blazer in progress
  5. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Mickey....Mickey...Mickey....
    There is many differences between the years as far as the wiring goes...from what I can see they even changed some of the colors around. It is better to get a Chiltons or a Haynes manual specific to your year truck that will show the diagram for your truck. That way you will be assured you have the right wires and make no mistakes tracing down the wrong wires and the wrong colors.
    Just my .02...
    <font color=green>[​IMG]Eagle86K5[​IMG]<font color=red>
    Masonry...It's a Good Thing
    2B1ASK1
  6. CruisinK5
    CruisinK5 1/2 ton status
    Jul 8, 2000
    164
    Georgia
    You said something about a new steering arm. If the truck has been lifted you need a drop down steering arm. JcWhitney has them for about $55.
  7. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    Wiring diagram? This may sound crazy but try the library, they may have the shop manual on their shelf, but you do want to get the 73 diagram, i have a 75 and a guy with a 73 stopped me on the street one day, seems he fryed his underhood harness and wanted to take a look at mine cause he pulled a harness out of a different year and whanted to see where everything went, well it turned out that his 73 my 75 and whatever year he pulled the harness out of were all different enough that both of us were confussed as hell.
    the batt cable is supposed to go to the alt bracket
    as for the rest i think the other guys were right on.
    RaisedK5
    "Friends don't let friends drive Fords"
  8. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Hey Laketex did you get your service manual from Helm or dealer?
    YEEEEE HAWWWWW[​IMG]
  9. laketex
    6,220
    North Texas
    Actually I got the service and the repair manuals both from a booth at the Peyton swap meet at Texas Motor Speedway. Got both for 50 bucks. The only problem is that they're originals, and being 21 years old, you've got to take care of them.
    [​IMG][​IMG]
    Durant, Ok
  10. MuleMaster
    MuleMaster 1/2 ton status
    Mar 2, 2000
    147
    Wayne, NJ 0747
    Diana,
    as to the wiring diagram: I got a shop manual (reprint) for my '78 from http://www.chevyduty.com. It contained a complet wiring diagram. They've got it for the '73, too for $49.95.
    Hope this helps!
    CU
    MuleMaster
    <font color=blue>K5 Blazer...because size DOES matter
    http://projectmule.coloradok5.com</font color=blue>
  11. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    check out http://www.painlesswiring.com/
    They sell wiring harnesses for
    exact replacement fit. My '80K5 was
    all over the road 'til I put in new ball joints,
    about $110 less labor.
    SteveB
  12. Michael
    1,576
    Sherman, Texas
    You're right Eagle about different colors and such. I guess I was being too general. But, the overall ignition circuits are very similar. I sometimes forget that wiring is a big mystery to lots of folks......not that I'm smarter or anything, it's just that I've messed with wires for about 30 years now. I think everyone's advice to pick up a year model specific manual is a good idea if ya don't have lots of experience tinkerin'. Sorry if I lead anyone astray.
  13. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    For your wandering problem, ask an alignment shop to check your tie-rod ends and upper and lower ball-joints, and of course, align it.
    73-87 Blazers have the tendency to crack the frame near the steering box. This could also be part of the problem. http://www.offroaddesign.com and Moose sell a repair kit for this.
    Hope this helps.
    <font color=blue>//////
    http://blazer79.coloradok5.com
    </font color=blue>[​IMG]
  14. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    You need a 4" lift at least to clear 35s and the guy probably put the quad shocks on because they weren't available until like '82. He could have put them on wrong which would explain the rubbing. You can change the seats out easily and you could get newer seats from a newer Chevy truck
  15. Eagle86K5
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Micheal ,
    You did not lead anyone astray...you were trying to help just like the rest for which you should be commended. My guess is someday we will meet at one of these things and bore the heck out of these folks talking bout electrical/electronic maladies. A day I look forward too.
    Thanks for helping Brother. And if I call you Mikey...it is because I have this mental pic ..."Give it to Mikey he will eat anything..."hehehehehehehehehehehehehe
    2B1ASK1
  16. Bruiser
    Bruiser 1/2 ton status
    May 21, 2000
    320
    Caldwell,Idaho
    Wandering driveing down road
    Check the frame where the steering box connects to it and make sure they have welded it up and added the necessary braces. If there isn't any there check for cracks on the frame, I found that mind wandered real bad and had play, my steering box was about to break of my frame, my be an important fix if it isn't fixed yet.
    Vincent Michels
    1978 Blazer
    Bruiser (Frost white/Black top/ Light Blue interior)
  17. Laurie
    Laurie Registered Member
    Jun 3, 2000
    44
    Oregon
    No suggestions to your questions but you came to the right place. These guys and gals have been so helpful and a great source of info. Have definitly saved $$$ by asking questions and reading about other peoples problems.
    Good Luck.
  18. MICHIGAN BLAZER
    MICHIGAN BLAZER 1/2 ton status
    296
    Middleville Michigan
    If your tires appear to be rubbing on the shocks, it sounds like it's a width problem w/the tire...not height. If it is that the tire is too wide, you could either purchase new rims w/different backspacing or buy spacers...or just live with it. I have an 89 w/35/12.50's & 4" of lift and i get mild rubbage of the front fenders under pretty good twist.
    <font color=red>MICHIGAN BLAZER
    <font color=green>89 Fullsize Blazer
    87 Cherokee
    65 IH Scout
  19. Michael
    1,576
    Sherman, Texas
    Hey Ray, thanks for the kind words.....I know us "sparky" guys always have a good plan in mind .....we just get confusing(confused?) sometimes. I get the "Mikey" deal allot.....he came about the time everyone was getting nick-names and I will eat most anything!!
    TallCowGirl.....I have this picture of a tall cow......anyway, let us know if we can help with the wiring....I can go look at my '74 and make ya sketch of all the important stuff so you can start with a key.
