Have some ? about parts I need
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wayne, Jul 26, 2001.
  1. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    OK, I was going to put the 89 Jimmy on hold for a few weeks because of tring to buy a house, but I decided I have a couple of months to get things done so I am not pushed after I move (I hope) and can make the Paragon run with some of the mods done. This is what I need to get answers for:
    1. Getting the custom brake lines made and called AAI Motersports and they need to know what size the female fitting is at the frame. Is it 3/8 or 7/16?
    2. Need to know the part number for the rear conversion U-joint for a 14ff? I have a 10 bolt now. I will most likely get it at Napa.
    3. Lug nut size for a Dana 60 and 14ff? I am looking for lugnuts that cover the whole stud. Boss if you read this probably the same ones that you have.
    4. Gear lube you reccommend for a Dana 60 and a 14ff both with lockers in them.
    I hope to ba able to have all my parts in the next few weeks and I figure it should take a week to get it all done. Thanks.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  2. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    1. Getting the custom brake lines made and called AAI Motersports and they need to know what size the female fitting is at the frame. Is it 3/8 or 7/16? When I got mine made, 3/16 was what I requested. That's the size that comes out the frame.
    2. Need to know the part number for the rear conversion U-joint for a 14ff? I have a 10 bolt now. I will most likely get it at Napa. Napa Part # 447 (1330/1350)
    3. Lug nut size for a Dana 60 and 14ff? I am looking for lugnuts that cover the whole stud. Boss if you read this probably the same ones that you have. 9/16"
    4. Gear lube you reccommend for a Dana 60 and a 14ff both with lockers in them. I used 80w90w
    Hope this helps
    Boss
    89' 1 TON of FUN K5
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    I second everything Boss said!!! [​IMG]
    <font color=blue>Daddy told me while learning to pee......"if you shake it more than twice, then you are playing with it!!!"</font color=blue>
