have you ever put your intake on to realize
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by solowookie, Apr 2, 2002.
  1. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    that you left your ratchet & socket under it? /forums/images/icons/tongue.gif LOL - and then get so excited to see the intake on that when you go to prime it you forgot to put the oil pressure sender in so you get an old faithful effect?
  2. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    yea, lol, did that on my friends car. i was pissed cause when it came time to tighten the intake i could not find the 9/16 socket and ratchet... but i had an excuse, i was on my fourth or fifth 40-ouncer...
    ARQ.
  3. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    yea well I was sobber /forums/images/icons/tongue.gif LOL - I did the same thing started looking for my ratchet so I could take them down a bit before torqueing it.
  4. tRustyK5
    Jul 23, 2000
    36,170
    1,376
    E-town baby!
    I once forgot to tighten the oil pan bolts. I got them all started and then must have went inside for a drink. Needless to say it made a helluva mess when I started it up!/forums/images/icons/blush.gif
    Rene
  5. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Off topic but the first time a changed my oil (not on the K5) I took off the old oil filter,and forgot to put the new one on. I felt like a jackass...LOL /forums/images/icons/smile.gif
  6. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    well I think that's what this post is about - feeling like a jackass... /forums/images/icons/wink.gif LOL
  7. tRustyK5
    Jul 23, 2000
    36,170
    1,376
    E-town baby!
    I once ( a long time ago...) forgot the drain plug during an oil change. Nothing like having all that nice new oil draining out as you're pouring it in. /forums/images/icons/tongue.gif
    Rene
  8. donimator
    donimator 1/2 ton status
    Jun 11, 2001
    444
    Tacoma WA
    We did a cam swap on our racecar motor one time. We put a nice clean rag in on the block to keep any stuff from entering the motor. Well, we got it all ready and put silcone on it any everything. Put the intake on and put some bolts in and when I went to wipe my hands down with the rag, I couldn't find it. It took us about 45min to realize what happend. we then pulled it back apart, ruining the gaskets in the process. We laughed about it then and still do now. /forums/images/icons/laugh.gif
  9. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    That is so funny, I did the same thing. But I did realize it as soon as the bolts were torqued, I looked down the distributor hole, and saw some cloth. /forums/images/icons/shocked.gif, I say WTF, oh *%#$!*&, and scramble to get the rag pulled out the hole/forums/images/icons/laugh.gif
  10. mudrunner78
    mudrunner78 1/2 ton status
    Sep 7, 2001
    366
    Rocksprings, TX
    speaking of beer and motors, I got alittle drunk(ok I was wasted) and ended up leaving a beer can in one of the bores of my 396. Found it when we turned the motor over by hand to set valve lash. Man did I feel like a jackass. Jesse
  11. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    #1 on my list of things NOT to do when I replace my intake this weekend. Leave the wrench under the intake. Thanks for the heads up! I'm sure I'll find something else to screw up though!!!! But I'll NEVER admit it!
  12. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Never left a ratchet under an intake, but I've done the old faithful thing. I rebuilt and installed the engine in my 72 L82, got in a rush, fired it up, and oil went everywhere ‘cause I left out the gauge fitting. High volume oil pump, jumped to about 2000 rpm idle, god what a mess...
  13. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    No. Got a hot seat after sitting on a fresh weld that my buddy conviently made for me while I was grinding another section of frame.
  14. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    When I was installing my shift kit, I was almost done and I found a little screen that goes on the opposite side of the separator plate. I had to remove everything again. What a pain in the A$$.
  15. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    yea well this gets even better /forums/images/icons/tongue.gif I'm sitting in bed last night realizing that the blocking ports that are suppose to go on the rear watter passages of a TBI intake are on the front! /forums/images/icons/mad.gif
    well looks like I get to go purchase some new intake gaskets today & do it all over again! /forums/images/icons/tongue.gif
  16. Quack_Addict
    Quack_Addict 1/2 ton status
    Feb 24, 2002
    119
    Michigan
    The starter in my`82 K5 with 6.2L died and I didn't shim the new one. The engine was airlocked (changed fuel filters too), so luckily it didn't start... when I let go of the key the starter didn't stop - the starter didn't return and kept cranking! I popped the hood to find the insulation on the battery cables literally starting to melt - with the starter still turning (luckily it was winter and I had gloves on) and ended up yanking on the pass-side battery + cable until I broke it off, stopping the starter. That's how I learned how important it is to properly shim a starter.
  17. lsak5
    lsak5 Registered Member
    Mar 19, 2002
    26
    Marietta, GA
    Ok, the last time I tried to adjust me Edelflock carb before getting another Q jet, the whole thing was in pieces, well I got it all put back together just fine, but forgot to hook up the fuel line on reinstall. Needless to say, when she cranked she was SMOKIN', Burned up some wiring and wiper skeet juice lines. Guess that will learn me.
  18. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I've done the put-the-intake-gaskets-on-backwards trick before. Couldn't figure out why the damn engine would get hot so quickly. This was on a TPI engine, and I discovered it after it was in the truck. Taking that all back apart was a royal PITA! /forums/images/icons/blush.gif
  19. TwoCrowsDesign
    TwoCrowsDesign 1/2 ton status
    Jul 13, 2001
    387
    Ahh, I left a rag in a fan shroud on a VW beetle motor (air-cooled) and melted the better part of both aluminum cylinders on that side of the engine. Doh!
  20. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    got the new intake gasket on this morning - man that was a mess to clean up! /forums/images/icons/tongue.gif I put RTV on the underside of the gasket (weird gasket - called for RTV on the underside, but nowhere else).
    anyway now I got little pieces of RTV in the valley - got out all I dared, but after a certain point it just seemed like I was getting more in then I was getting out. guess my oil filter will have to catch it, or the screen.
