have you ever?
Discussion in 'Audio' started by balzer, Aug 5, 2000.
  1. balzer
    balzer Registered Member
    Jul 31, 2000
    39
    i was wanting to know if anybody has run 2 4-ohm subs bridged on a regular amp, making it run beyond its impedence level, rather than 2 4-ohm stereo or 2 8-ohm bridged. i wasnt planning on it, just wanting to know, i heard it will make you amp work alot harder and might overheat and shutdown.
    thanx
  2. CrazeeBush
    CrazeeBush 1/2 ton status
    Apr 17, 2000
    464
    Middle Tennessee
    I have 2 4 ohms subs wired in parallel to make a 2 Ohm load. My amp is designed to handle a 2 Ohm mono load so it's safe. If you do that, you better put some fans on it. Also some amp won't allow you to drop impedance that low.
    -JoSH
    crazeebush@aol.com
    http://josh.coloradok5.com
  3. DBLAZER
    DBLAZER 1/2 ton status
    Apr 2, 2000
    1,716
    Haslet, Tx
    One of the things you want to consider when ever you run a lower ohm load is Dampening Facter. That is basically the control your amp has of your woofer. The lower the ohm load, the lower the dampening factor the less controle over your woofer, all adds up to distortion and distortion is a woofer killer and an amp killer.
    89 w/DANA 60-Corp 14 w/5:13s n Detroit's. 4"lift 2" body. AtlassII . Spray in liner.
  4. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    I've done it on amps that don't recommend it. High quality amps. And I've never had a problem. It depends what kind you have. Brand, model, age???
    '73 K5
    Chevy good...Ford bad
  5. 82Jimmy
    82Jimmy 1/2 ton status
    Jun 9, 2000
    702
    Theres one of my friends here that has 2 massive 15's on a 600legacy amp (older model) down to 1 ohm...he can push his speakers for about 10minutes before the amp gets really hot. Sounds okay, but when he has beer back there it gets them really hot and sweaty. [​IMG]
    <font color=blue>If its too loud, your too old.</font color=blue>
    http://82Jimmy.coloradok5.com
  6. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    I have done that with $H!#Y amps, If you run a big power wire and have some air flow you will be ok.
    I have ran 3 4-ohm subs on a old @$$ JVC before, that died after 9 months. But if you have a half way good amp you will be ok.
