Have your chrome valve covers leaked?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by spincast375, Nov 25, 2004.
  1. spincast375
    spincast375 1/2 ton status
    Aug 20, 2004
    194
    Tennessee, U.S.A.
    Mine do; some have told me chrome never give you a good fit and will always leak. I have the original covers. I am about to change out the valve cover gaskets. Am I better off to scrap the chrome? Engine is a rebuilt big block 454 cu. in.
  2. bigchief427
    bigchief427 Registered Member
    Dec 7, 2003
    35
    martinsville indiana usa
    nope and they are kinda cheap looking things that were on the truck when i got it I did put some rubber gaskets on the cover for giggles i try and keep em tight also
  3. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    every chrome set I have owned leaked, on 3 diff motors, I think its because chrome doesn't radiate heat it holds in more than normal metals. I blame that extra heat for never sealing right. I have new gaskets and refinished covers just need to make time.
  4. Silverado_K5
    Silverado_K5 1/2 ton status
    Jun 4, 2003
    707
    Weston, Oregon
    On chrome accessories, you need to scuff the gasket surface up with something to take the chrome off. I use a cut off wheel die grinder tool with roll lok scotch brite pads and treat the gasket side like I do for removing gaskets from machine surfaces. Hope that helps.
    Doug /forums/images/graemlins/truck.gif
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Bingo. /forums/images/graemlins/thumb.gif
  6. wasted wages
    wasted wages 3/4 ton status
    Dec 3, 2003
    9,194
    Dallas Texas
    A trick the has worked for me is to use cork gaskets,,aviation hi tack permatex glued to the cover ONLY,,,then use some grease on the side that will contact the head,,
    use a set of hold downs that spread the bolts clamping force evenly across the lip of the covers & tighten down just enough to compress the gasket,,,The best thing is to use is a set of aluminum covers,,,they seal so much better.
  7. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    I've thrown away mine,opted for some aluminun ones and polished them up,look great.... /forums/images/graemlins/usaflag.gif
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    When I do buy crome, I always get the AC Delco [​IMG] I like the tall ones. On older vehicles crome looks good.
  9. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I have the same ones Z3PR showed, they don't leak.
  10. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    I had the same problem and I switched to the aluminum and a rubber gasket and have zero problems.
  11. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    I don't remeber if BB had the hold down tabs, maybe just bolts.
