having elec. problems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sapper, Apr 22, 2002.
  1. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    for some reason my turn signals will work sometimes and sometimes they dont. coming home today i had them then the light would just come no blinking and then they worked as i pulled into the house then just a light agian. think its something with the coloum but i'v never taken it apart and have no idea what to look for so any help would be great. thanks
  2. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    I have heard that there is a little plastic cam inside of the collumn that wears out but am not sure. Might have to tear into the collumn to see whats wrong. But before you do it make sure that the outside lights are in conjunction with your inside lights. On my truck sometines the left turn light woun't flash, but they are on the outside, and other times they all work properly. Just a thought.
  3. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Try replacing the flashers in the fuse block. They're cheap and usually the cause of no blinking
  4. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    If your light in the dash comes on steady it can mean one of the bulbs has gone out or lost connection. I would try cleaning all the sockets.
  5. sapper
    Jul 11, 2001
    3,052
    NoVa
    both bulbs are replaced the flasher in fuse box is new had to replace it to tow. might try another one tommarow to see. thanks
  6. 1979Jimmy
    1979Jimmy 1/2 ton status
    Nov 14, 2001
    696
    Danville Ca
    i got a question about that too. My right blinker works normaly but my left blicker will come on outside on the lights of the truck but on the dash it wont blink or turn off automatically whats the deal?
  7. 1979Jimmy
    Nov 14, 2001
    696
    Danville Ca
    anyone?
  8. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Well since I am the blinker guy..I would try new bulbs ,and a new flasher.
  9. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I have bought two trucks now that the previous owner had tapped in with the trailer lights right at one of the rear turn signals and that signal was shorting out. I would check there first. I have seen many interesting things on different trucks. It may even be a bad ground in that area.
  10. 1979Jimmy
    Nov 14, 2001
    696
    Danville Ca
    thanks all, but whats up with it not turning off after i make a turn?
  11. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I had the same problem with my truck and the wiring installed for trailer lights. Mine had a "T" that connected into the factory wiring, took the "T" out and the problem was solved.
  12. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Theres a canceling cam behind the steering wheel that turns off the blinkers when your straighten the wheel and it has springs on it that fall off a lot. Mine does the same thing, I gotta pull the wheel off some time and see if a spring fell out or the cam broke
  13. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    On mine the cam broke - it's an easy junkyard fix. On another truck things were getting sticky and a little cleaning and white grease got rid of the sticking and clicking before the piece broke.
