having problems with new bearings & hub assembly
Discussion in 'The Garage' started by savagek5diesel, Feb 21, 2005.
  1. savagek5diesel
    savagek5diesel 1/2 ton status
    Nov 20, 2003
    310
    Redding California
    Hey guys, my front left wheel bearing took a digger, i got a new spindle and new bearing and what not, when i got it all put back together there was still a bit of play with the hub housing/rotor. can anybody give me an a quick walkthrough guide to what i might have missed?
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    sure to torque down the 2 nuts? sure installed the new races properly? Got the 2 snap rings in?
  3. ssls6
    ssls6 Registered Member
    Jan 5, 2005
    86
    Dallas, TX
    There is suppost to be some play (like 0.001 or something). The spec is torque the inner nut to 50ft-lb, back it off, retorque to 35ft-lbs, back it off 1/4 turn. When you do this it will be somewhat loose which gives the specified play.
    All I know for sure is I once had my wheel bearings too tight and they self destructed within 100 miles.
  4. savagek5diesel
    Nov 20, 2003
    310
    Redding California
    what snap rings? the only one i know about it the one for the auto lock hub.
  5. savagek5diesel
    Nov 20, 2003
    310
    Redding California
    i think i figured out the problem.... there's an inner spindle bearing, a bearing that goes inside the back of the hub housing, and a third one that goes behind the hub nuts??? is this correct?
  6. ssls6
    Jan 5, 2005
    86
    Dallas, TX
    1 spindle bearing, 1 spindle seal, 1 spindle bevel washer
    1 inner wheel bearing & race, 1 inner wheel bearing seal
    1 outer wheel bearing & race
    If you put a large inner wheel bearing on a small bearing spindle, you'll get lots of slop. Remeber that the spindles come in two sizes (large and small).
  7. savagek5diesel
    Nov 20, 2003
    310
    Redding California
    perfect, the zone didn't give me the inner bearing but they gave me the seal for it. thanks a million.
  8. savagek5diesel
    Nov 20, 2003
    310
    Redding California
    all fixed now thanks guys.
