having rear end troubles! someone help
Discussion in 'The Garage' started by 76k5wheeler, Jan 4, 2005.
  1. 76k5wheeler
    76k5wheeler Registered Member
    Nov 2, 2004
    9
    dahlonega ga
    hey guys i have a 76 k5 with a 350,465,205 with a 12 bolt and ten bolt the rearend is binding up going down the road anyone have suggestions
  2. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Hard to be of any assistance without more information.
    Is the bind a new thing? how is it binding up? Is it from a lift installation? have you changed anything that would now cause bind?
  3. 76k5wheeler
    Nov 2, 2004
    9
    dahlonega ga
    no lift,havent changed a thing it just binds up like the breaks are on when putting power to it but u can coast and it rools fine
  4. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    766
    Granbury, TX
    does it have a posi in there? many came from factory with a posi in the rear, could be going?
    or maybe the question should be *did* it have a posi?
  5. 76k5wheeler
    Nov 2, 2004
    9
    dahlonega ga
    no its open
  6. dyeager535
    26,980
    Try jacking it up and turning the wheels by hand, feeling for resistance. Doesn't sound like brakes, but you could pull the drums off at the same time to check.
    I'd pull the cover, open diffs tend to eat through the pinion gear cup washers, and then bind up. Probably slowly grinding the gear teeth down.
  7. 76k5wheeler
    Nov 2, 2004
    9
    dahlonega ga
    anyone know what my problem is it rolls fine but when u put power to ir it binds
