having some strange steering problems
Discussion in 'The Garage' started by fright89, Dec 6, 2002.
  1. fright89
    fright89 1/2 ton status
    Sep 27, 2001
    279
    boston
    Started having some strange steering problems a little while ago. Put up a few posts and decide to start replacing front-end parts. Briefly the problem was after a slow turn backing up or pulling out of my driveway the thing would pull hard to the right real hard and I would have to compensate real hard on the wheel then it would free up a and I would go to the left because I was over compensating the pull to the right. Was loose going straight. Would not track good going straight always to the left or right.
    So I have replaced
    Steering box
    Tie rod ends
    Connecting rod
    And adjusted toe in
    When I jack the front end up everything is tight. If I am checking everything correctly. I think I am. I am not a mechanic by trade.
    I can tell when I drive that the new parts made a great improvement but I am still getting a little wondering. Coming out of a curve at speed it seems like it still wants to keep turning and wanders back the other way.
    Got some snow last night so we went out for a cruse and I was really getting pulled around in the slush. Changing lanes on the hiway was scary. Just seems to wander off to the left or right. Seems as thou I have missed something.
    I did notice some sort of connection by the firewall on the steering column, do those ware out? Or could the whole column be bad?
    Any help on checking ball joints, seem fine, or any suggestions on what to look at next would be appreciated. Thanks
  2. GMslave
    GMslave 1/2 ton status
    Oct 3, 2002
    113
    Flint, Michigan
    Do you have a steering stabilizer? If so, check it. If not, buy one.
  3. fright89
    Sep 27, 2001
    279
    boston
    I replaced that also. forgot to put it on the list.
  4. GMslave
    Oct 3, 2002
    113
    Flint, Michigan
    Well, I'm out. Anybody?
  5. Shagnaz
    Shagnaz 1/2 ton status
    Jul 19, 2002
    308
    South Carolina, North Charleston
    I am in the a situation like you. I just install my Dana 60 and between 30 and 40 I get wobble. I only have 4" lift with 33's (for now). I have been changing parts out also, but I still get that wobble.
    Good luck!
    Are you have any clicking noises when you turn the wheel full left to full right or vise-versa?
    I had that before I went to 1 ton. It was my steering box.
    Mike B
  6. fright89
    Sep 27, 2001
    279
    boston
    Do a search for death wobble. I think it is a well-documented problem.
    Mine just feels loose.
    I will be going up to NH next weekend and would really like to get this figured out. I will take another look this morning but would much rather be out playing in the snow.
    Anybody?
  7. fright89
    Sep 27, 2001
    279
    boston
    got it fixed thismorning and still had time to go wheeling in the snow /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif
