having trouble getting the distributor rotor out
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BayouBlazer88, Aug 31, 2003.
  1. BayouBlazer88
    BayouBlazer88 1/2 ton status
    Jul 31, 2002
    353
    Lafayette, LA
    I have an HEI distributor with the remote coil (88' 350tbi) that has the pressed in rotor. The distributor looks to be the original and so I'm having trouble getting the rotor out. Is there any tricks to pulling it off without breaking anything or having to pull the distributor out of the engine?
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The rotor is just pressed onto the shaft. Sometimes you have to pull pretty hard to get it to come off. /forums/images/graemlins/eek.gif A little rust on the shaft will hold onto the rotor pretty tightly.
  3. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Hummm...my 88 350 distributor had 2 screws on the rotor which attach it to the advance plate. I dont ever recall seeing an HEI with a pressed on rotor /forums/images/graemlins/confused.gif
  4. BayouBlazer88
    Jul 31, 2002
    353
    Lafayette, LA
    Does yours have the coil built into the cap of the distributor? Because mine has a remote coil. GM may have changed the trucks ignition system in 88' and left the blazers and burbans the same or vice-versa. But mine definitely has no screws in the rotor and neither does the new one.
  5. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Maybe he means the entire shaft, not just the plastic rotor under the cap.
  6. BayouBlazer88
    Jul 31, 2002
    353
    Lafayette, LA
    /forums/images/graemlins/thumb.gifFinally got it off. I gave up trying to pull it off with the distributor in the truck so I pulled the whole thing out, put the rotor in a vice, and yanked. Came right off when I threw my weight into it. Hopefully the new cap and rotor will correct the problem. Thanks for the help guys.
    -And no, I'm not talking about the whole distributor shaft. The rotor itself is pressed on with no screws holding it in. I think the only kind that is attatched with screws are the ones with the coil mounted on top of the distributor.
  7. 88Silverado
    Mar 13, 2003
    2,664
    Interesting /forums/images/graemlins/thinking.gif
    Sounds like the old points/rotor setup with push-on rotor.
    Learned something new /forums/images/graemlins/thumb.gif
  8. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    my '88 has the same rotor, and it was a bitch to get off also.
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Funny, my '87 has the same one. It came right off last time.
